Problem integrating SD card with Rotary Encoder and LCD screen - Arduino Mega
Hi everyone,
I've been trying to get a project to work that involves an LCD display, rotary encoder and now an SD card.
I've managed to get the LCD display and rotary encoder to work successfully but when I add the SD module the rotary encoder doesn't work correctly, the buttonPin will work but the rotary encoder part stops working.
#include <time.h>
#include <SPI.h>
#include <SD.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(43,41,39,37,35,33);
#define outputA 51
#define outputB 49
#define buttonPin 47
char lcdmsg1[] = "Bioreactor LCD  ";  //printed at startup
char lcdmsg2[] = "v3.0"; // printed at startup
char lcdmsg3[] = "Initialising... ";
char lcdmsg4[] = "Ready           ";
char mainMenuR1[] = "A      ";
char mainMenuR2[] = "B        ";
char mainMenuR3[] = "C        ";
char mainMenuR4[] = "D        ";
  lcd.begin(16,2); //set up the size of the LCD screen (16 characters by 2 lines)
  lcd.print(lcdmsg1);
  lcd.setCursor(0,1); // move to the second line of the LCD
  lcd.print(lcdmsg2);
  lcd.setCursor(0,1);
  lcd.print(lcdmsg3);
  //LCD Screen setup
  pinMode(outputA,INPUT);
  pinMode(outputB,INPUT);
  pinMode(buttonPin,INPUT_PULLUP);
  pinMode(LEDPin,OUTPUT);
  Serial.println("Initialisiation begun...");
  aLastState = digitalRead(outputA); // get initial value of outputA
if(!SD.begin(53)) { //SD card not recognised
    Serial.println("SD Card not recognised");
    SD_err=true;
    lcd.setCursor(0,1);
    lcd.print(SDerror);
    for (int i = 0; i<10; i++){
      digitalWrite(DIODES_PIN_A, HIGH);
      digitalWrite(LEDPin, LOW);
      digitalWrite(DIODES_PIN_A, LOW);
      digitalWrite(LEDPin, HIGH);
  else{ //Declare SD card is OK
    Serial.println("Wiring is correct and SD card is initialised correctly");
    lcd.setCursor(0,1);
    lcd.print(lcdmsg5);
   drawMenu(); // Displays the current selections
   rotaryMenu(); // Checks for alterations to the rotary encoder and updates accordingly
   ButtonTest(); // Cycles through all the button permeatations and implements accordingly.
void rotaryMenu(){
  aState = digitalRead(outputA); //read the state of outputA
  buttonPressed=digitalRead(buttonPin); //check if buttonPin has been pressed
   if(aState != aLastState){ //If outputA has changed then decide which way it has moved
    if (digitalRead(outputB) != aState){ // Case for CW movement
      counter++;
      down=true; //set variable to move down a selection in  the menu
    else{ //Case for CCW movement
      counter --;
      up=true; //set variable to move up a selection in the menu
    /* Code for testing the RotaryEncoder works
    lcd.setCursor(0,1); //set the position of the column and row you are printing to
    // NB both col and row start with */
    /*Serial.print("OutputA: ");
    Serial.println(outputA);
    Serial.print("OutputB: ");
    Serial.println(outputB);
    Serial.print("Position: ");
    Serial.println(counter);
    //lcd.print("                    ");
    lcd.print("Counter: ");
    lcd.print(counter);
    lcd.print("       "); // Gets rid of any trailing numbers on the display.
   int LEDcurrent = digitalRead(LEDPin);
   /*Serial.print("LEDcurrent: ");
   Serial.println(LEDcurrent);
   Serial.print("Button Pressed: ");
   Serial.println(buttonPressed);
   //Button Pressed
   if(buttonPressed == LOW){
    middle=true; //output to select buttonPressed functions elsewhere
    if(LEDcurrent == HIGH){ //Operate LED if attached
      //turn LED off
      digitalWrite(LEDPin,LOW);
      delay(500); //add delay for user pressing
    if(LEDcurrent == LOW){ //Reverse of above LED operation (if attached)
      //turn LED on
  aLastState=aState; //set the comparison state to the current state
void drawMenu(){
  /* Main menu
  if (page == 1){
    lcd.setCursor(0,1);
    if(menuitem==1){
      lcd.print(mainMenuR1);
    if(menuitem==2){
      lcd.print(mainMenuR2);
    if(menuitem==3){
      lcd.print(mainMenuR3);
    if(menuitem==4){
      lcd.print(mainMenuR4);
void ButtonTest(){
  /*Up
  //Main Menu
  if (up && page == 1){
    up=false;
    menuitem--;
    if(menuitem==0){ // catch all to stop at the top of the menu
      menuitem=1;
   /* Down
    // Main Menu
   if(down && page == 1){
    down =false;
    menuitem++;
    if(menuitem ==5){ //catch all to stop at the bottom of the menu
      menuitem--;
/* Button Pressed
   if (middle){
      middle = false;
      //Main Menu
      if (page == 1 && menuitem == 1){ //Enter batch culture submenu
        page++;
        delay(debounceTime); // Pause to stop double tapping and flicking between menus
        Serial.print("Page: ");
        Serial.println(page);
        Serial.print("MenuItem: ");
        Serial.println(menuitem);
        Serial.print("Frame: ");
        Serial.println(frame);
I'm sure it's something really simple that I'm missing but can anyone give me some help?
Thanks
This pin which I guess is one of the encoder's....
#define outputA 51
... is the SPI MOSI on a Mega.
Awesome, thanks so much fishBone! I thought the SPI MOSI on the Mega was in the ICSP only but you're right, I should have noticed that!
As I se it, you have to ADD #include <rotary.h>
#include <rotary.h>
//Define rotary encoder pins
#define PINA 11
#define PINB 12
#define PUSHB 13
// Initialize the Rotary object
// Rotary(Encoder Pin 1, Encoder Pin 2, Button Pin) Attach center to ground
Rotary r = Rotary(PINA, PINB, PUSHB); // there is no must for using interrupt pins !!
Find Rotary_Button.zip here:
http://www.planker.dk/Projects/Arduino/Rotary_Button.zip
