I was tinkering with a magnetic swipe decoder and an LCD display. I found some code on decoding the magnetic stripe reader written by Stephan King (which I have used below).
Basically, I wanted to add on to the code so that the output (decoded magnetic info) went to an LCD as well. I am using an Arduino Duemilonavae w/ Atmega 328 and an HD44780 LCD.
I added added some code to Mr. King's in an attempt to get the data to display on the LCD, but I am only receiving a series of straight lines. Can anyone tell me what i'm doing wrong? Or give me advice in general on how to send serial data to an LCD? Here's the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int cld1Pin = 4; // Card status pin
int rdtPin = 2; // Data pin
int reading = 0; // Reading status
volatile int buffer[400]; // Buffer for data
volatile int i = 0; // Buffer counter
volatile int bit = 0; // global bit
char cardData[40]; // holds card info
int charCount = 0; // counter for info
int DEBUG = 0;
char actual_buf[255];
boolean printToLCD = false;
lcd.begin(16,2);
// The interrupts are key to reliable
// reading of the clock and data feed
attachInterrupt(0, changeBit, CHANGE);
attachInterrupt(1, writeBit, FALLING);
lcd.print("Please Swipe Card");
void loop(){
// Active when card present
while(digitalRead(cld1Pin) == LOW){
reading = 1;
// Active when read is complete
// Reset the buffer
if(reading == 1) {
if (DEBUG == 1) {
printBuffer();
decode();
reading = 0;
i = 0;
int l;
for (l = 0; l < 40; l = l + 1) {
cardData[l] = '\n';
charCount = 0;
// Print to LCD
if (printToLCD) {
lcd.clear();
int j = 1;
while(cardData[j] <= 16) { //!= '=' && j
lcd.print(cardData[j]);
j++;
printToLCD = false;
// Flips the global bit
void changeBit(){
if (bit == 0) {
bit = 1;
bit = 0;
// Writes the bit to the buffer
void writeBit(){
buffer[i] = bit;
i++;
// prints the buffer
void printBuffer(){
int j;
for (j = 0; j < 200; j = j + 1) {
Serial.println(buffer[j]);
int getStartSentinal(){
int j;
int queue[5];
int sentinal = 0;
for (j = 0; j < 400; j = j + 1) {
queue[4] = queue[3];
queue[3] = queue[2];
queue[2] = queue[1];
queue[1] = queue[0];
queue[0] = buffer[j];
if (DEBUG == 1) {
Serial.print(queue[0]);
Serial.print(queue[1]);
Serial.print(queue[2]);
Serial.print(queue[3]);
Serial.println(queue[4]);
if (queue[0] == 0 & queue[1] == 1 & queue[2] == 0 & queue[3] == 1 & queue[4] == 1) {
sentinal = j - 4;
if (DEBUG == 1) {
Serial.print("sentinal:");
Serial.println(sentinal);
Serial.println("");
return sentinal;
void decode() {
int sentinal = getStartSentinal();
int j;
int i = 0;
int k = 0;
int thisByte[5];
for (j = sentinal; j < 400 - sentinal; j = j + 1) {
thisByte[i] = buffer[j];
i++;
if (i % 5 == 0) {
i = 0;
if (thisByte[0] == 0 & thisByte[1] == 0 & thisByte[2] == 0 & thisByte[3] == 0 & thisByte[4] == 0) {
printMyByte(thisByte);
Serial.print("Stripe_Data:");
for (k = 0; k < charCount; k = k + 1) {
Serial.print(cardData[k]);
Serial.println("");
printToLCD = true;
void printMyByte(int thisByte[]) {
int i;
for (i = 0; i < 5; i = i + 1) {
if (DEBUG == 1) {
Serial.print(thisByte[i]);
if (DEBUG == 1) {
Serial.print("\t");
Serial.print(decodeByte(thisByte));
Serial.println("");
cardData[charCount] = decodeByte(thisByte);
charCount ++;
char decodeByte(int thisByte[]) {
if (thisByte[0] == 0 & thisByte[1] == 0 & thisByte[2] == 0 & thisByte[3] == 0 & thisByte[4] == 1){
return '0';
if (thisByte[0] == 1 & thisByte[1] == 0 & thisByte[2] == 0 & thisByte[3] == 0 & thisByte[4] == 0){
return '1';
if (thisByte[0] == 0 & thisByte[1] == 1 & thisByte[2] == 0 & thisByte[3] == 0 & thisByte[4] == 0){
return '2';
if (thisByte[0] == 1 & thisByte[1] == 1 & thisByte[2] == 0 & thisByte[3] == 0 & thisByte[4] == 1){
return '3';
if (thisByte[0] == 0 & thisByte[1] == 0 & thisByte[2] == 1 & thisByte[3] == 0 & thisByte[4] == 0){
return '4';
if (thisByte[0] == 1 & thisByte[1] == 0 & thisByte[2] == 1 & thisByte[3] == 0 & thisByte[4] == 1){
return '5';
if (thisByte[0] == 0 & thisByte[1] == 1 & thisByte[2] == 1 & thisByte[3] == 0 & thisByte[4] == 1){
return '6';
if (thisByte[0] == 1 & thisByte[1] == 1 & thisByte[2] == 1 & thisByte[3] == 0 & thisByte[4] == 0){
return '7';
if (thisByte[0] == 0 & thisByte[1] == 0 & thisByte[2] == 0 & thisByte[3] == 1 & thisByte[4] == 0){
return '8';
if (thisByte[0] == 1 & thisByte[1] == 0 & thisByte[2] == 0 & thisByte[3] == 1 & thisByte[4] == 1){
return '9';
if (thisByte[0] == 0 & thisByte[1] == 1 & thisByte[2] == 0 & thisByte[3] == 1 & thisByte[4] == 1){
return ':';
if (thisByte[0] == 1 & thisByte[1] == 1 & thisByte[2] == 0 & thisByte[3] == 1 & thisByte[4] == 0){
return ';';
if (thisByte[0] == 0 & thisByte[1] == 0 & thisByte[2] == 1 & thisByte[3] == 1 & thisByte[4] == 1){
return '<';
if (thisByte[0] == 1 & thisByte[1] == 0 & thisByte[2] == 1 & thisByte[3] == 1 & thisByte[4] == 0){
return '=';
if (thisByte[0] == 0 & thisByte[1] == 1 & thisByte[2] == 1 & thisByte[3] == 1 & thisByte[4] == 0){
return '>';
if (thisByte[0] == 1 & thisByte[1] == 1 & thisByte[2] == 1 & thisByte[3] == 1 & thisByte[4] == 1){
return '?';
I assume that print to serial is giving you the correct output? I'm not sure what you mean by the lcd displaying only lines.
in:
// Print to LCD
if (printToLCD) {
lcd.clear();
int j = 1;
j++;
printToLCD = false;
I would start with j=0. It seems to me you need lcd.setCursor(0,0) somewhere.
Since the data can be 40 characters and you only have 32 characters on your LCD, I would have enclosed the while loop in a second loop (after the byte j=0; line) so that you can put the second line on the second line of the display.Something like this
Will only give you meaningful results if the cardData[] contains ASCII characters.
Use the monitor to print it out to the console first to see if you are getting correct data here first before you try the extra complication of an LCD.
Again I'm not sure what you mean about the LCD displaying only lines.
Sorry, I should have been more specific; I meant to say that it was only outputting gibberish--basically a series of vertical lines rather than numbers, the LCD looked basically like this: ||||||||||||
The code works just fine sending the data to my monitor. There's only an issue sending the data to my LCD. This is the code I currently have that is sending correct output to my serial monitor:
//initialize the library w/ the numbers of the inteface pins
int DEBUG = 0;
lcd.begin(16,2);
lcd.print("Ready...");
void loop(){
reading = 1;
// Reset the buffer
if(reading == 1) {
if (DEBUG == 1) {
printBuffer();
decode();
reading = 0;
i = 0;
int l;
cardData[l] = '\n';
charCount = 0;
// Print to LCD
if (printToLCD) {
lcd.clear();
int j = 1;
while(cardData[j] j <= 16)
j++;
lcd.write(0xC0);
printToLCD = false;
void changeBit(){
if (bit == 0) {
bit = 1;
bit = 0;
void writeBit(){
buffer[i] = bit;
i++;
void printBuffer(){
int j;
int j;
int queue[5];
int sentinal = 0;
if (DEBUG == 1) {
sentinal = j - 4;
if (DEBUG == 1) {
Serial.println("");
return sentinal;
void decode() {
int j;
int i = 0;
int k = 0;
int thisByte[5];
i++;
if (i % 5 == 0) {
i = 0;
Serial.println("");
int i;
if (DEBUG == 1) {
if (DEBUG == 1) {
Serial.print("\t");
Serial.println("");
charCount ++;
return '0';
return '1';
return '2';
return '3';
return '4';
return '5';
return '6';
return '7';
return '8';
return '9';
return ':';
return ';';
return '<';
return '=';
return '>';
return '?';
did you test the lcd with some standard test code or a simple lcd.print("abcd"); ?
Oh yes, definitely; that's the first thing I did. The LCD definitely receives/displays using the lcd.print command.
It's strange; you can tell the lcd is receiving something from each swipe; however it's like it's not displaying the information correctly. Are there any other examples of displaying information from a device to an LCD screen? I'm probably overlooking something basic...
if you're using the standard LiquidCrystal then
lcd.println("");
doesn't do anything good. the character gets sent to the LCD as though it were a displayable character rather than moving the cursor to the next line. (The goofy character is off the right edge of the LCD. You could see it by scrolling the screen to the left.)
There is that much RAM. Its telling the compiler that the RAM might change based on something external to what the compiler can otherwise know about. Thus the compiler should not use optimizations based on the idea that nothing changed since the last time the program touched it.
The compiled program may be shorter and faster without the use of volatile.
