Problem Interfacing "KCMR- 84ARS Digital Level Indicator" using UART
Hi EveryOne
I am trying to read Level Indicator meter (as slave) with master (esp32 ) ,using communication (MAX485).
I have connected PIN 16,17 as RX2,TX2 and using PIN 4 and 2 as a MAX485_DE & MAX485_RE_NEG respectively. I am getting error of "ku8MBResponseTimedOut" on serial print with response of "Inside Timeout Block". I also attached the operation Manual of "KCMR- 84ARS Digital Level Indicator" as well.
using the following
#include <ModbusMaster.h>
#include <ArduinoOTA.h>
#include "credentials.h"
#include<AWS_IOT.h>
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#define CLIENT_ID "payload1"// thing unique ID, this id should be unique among all things associated with your AWS account.
#define MQTT_TOPIC "$aws/things/DHT11-RS485/shadow/update" //topic for the MQTT data
#define AWS_HOST "a4ur6wss9ptht-ats.iot.eu-central-1.amazonaws.com" // your host for uploading data to AWS,
AWS_IOT aws;
#define RXD2 16  //RXD2
#define TXD2 17  //TXD2
#define MAX485_DE      4  //RX 729
#define MAX485_RE_NEG  2 //TX 728
ModbusMaster node;
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1);
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0);
  digitalWrite(MAX485_DE, 0);
float WaterLevel,WaterLevel1,WaterLevel2;
//SoftwareSerial mySerial(RXD2,TXD2); // RX, TX
  Serial.println("Booting");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Connection Failed! Rebooting...");
    delay(5000);
    ESP.restart();
  ArduinoOTA.setPort(3232); // Port defaults to 3232                            // ArduinoOTA.setPort(3232);
  ArduinoOTA.setHostname("OTA"); // Hostname defaults to esp3232-[MAC]               // ArduinoOTA.setHostname("myesp32");
  ArduinoOTA.setPassword("syedamin110");  // No authentication by default                     // ArduinoOTA.setPassword("admin");
  // Password can be set with it's md5 value as well  // MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
  ArduinoOTA.setPasswordHash("9539721a862a4209fb63f3be33cbf505");
  ArduinoOTA.onStart([]() {
    String type;
    if (ArduinoOTA.getCommand() == U_FLASH)
      type = "sketch";
    else // U_SPIFFS
      type = "filesystem";
    // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
    Serial.println("Start updating " + type);
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR)         Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR)   Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR)     Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("Ready");
  Serial.print("IP address: ");
  pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  // Init in receive mode
  // Modbus slave ID 1
  Serial2.begin(9600,SERIAL_8N1,RXD2,TXD2); //SERIAL_8N1
  node.begin(1, Serial2);
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
  //AWS Amazon
  Serial.println("\n  Initializing connetction to AWS....");
  if (aws.connect(AWS_HOST, CLIENT_ID) == 0) { // connects to host and returns 0 upon success
    Serial.println("  Connected to AWS\n  Done.");
  else {
    Serial.println("  Connection failed!\n make sure your subscription to MQTT in the test page");
  Serial.println("  Done.\n\nDone.\n");
  ArduinoOTA.handle();
  yield();
  Serial.println("Uploaded10");
  uint8_t result;
  node.clearResponseBuffer();
  result = node.readHoldingRegisters(0x40000,6);
  if (result == node.ku8MBSuccess)
    Serial.println("Reading WaterLeveL values");
    Serial.println(node.getResponseBuffer(0)); //This shows humidity Serial.print("%")
    float WaterLevel = (node.getResponseBuffer(0));
    Serial.println("WaterLevel");
    Serial.println(WaterLevel);
  Serial.println(node.getResponseBuffer(1)); //This shows humidity Serial.print("%")
    float WaterLevel1 = (node.getResponseBuffer(1));
    Serial.println("WaterLevel1");
    Serial.println(WaterLevel1);
     Serial.println(node.getResponseBuffer(2)); //This shows humidity Serial.print("%")
    float WaterLevel2 = (node.getResponseBuffer(2));
    Serial.println("WaterLevel2");
    Serial.println(WaterLevel2);
    //Sending Data to AWS
    // check whether reading was successful or not
    if (WaterLevel == NAN) { // NAN means no available data
      Serial.println("Reading failed.");
    else {
      //create string payload for publishing
      String payload1 = "WaterLevel: ";
      payload1 += String(WaterLevel);
      char payload[100]; //40
      payload1.toCharArray(payload, 100); //sprintf(payload,"Humidity:%f  Temperature:%f'C",h,t); // Create the payload for publishing
      Serial.println("Publishing:- ");
      Serial.println(payload);
      if (aws.publish(MQTT_TOPIC, payload) == 0) { // publishes payload and returns 0 upon success
        Serial.println("Success\n");
      else {
        Serial.println("Failed!\n");
  if (result == node.ku8MBResponseTimedOut)
    Serial.println("Inside Timeout block ");
  if (result == node.ku8MBInvalidCRC)
    Serial.println("Inside ku8MBInvalidCRC block ");
  if (result == node.ku8MBInvalidFunction)
    Serial.println("Inside ku8MBInvalidFunction block ");
  if (result == node.ku8MBInvalidSlaveID)
  if (result == node.ku8MBSlaveDeviceFailure)
    Serial.println("Inside ku8MBSlaveDeviceFailure block ");
  if (result == node.ku8MBIllegalDataValue)
    Serial.println("Inside ku8MBIllegalDataValue block ");
  delay(5000); //delay(4000);
KCMRS-84ARS.pdf (696 KB)
Perhaps AWS_IOT does not know how to switch between RS-485 transmit and receive, so that aws.connect() fails?
Actually sir, i dont have an issue of aws connection. Actually my Master is not reading slave register as i defined in my code according to the attached operation manual of "KCMR- 84ARS Digital Level Indicator". Kindly do help me out in this read holding register's Issue.
Thank you
The problem is switching the RS-485 half-duplex direction. After a command is sent to the device, the direction has to be reversed so that the device can send to the controller. Check the library code and documentation for eventual hints.
You do have the Modbus option with your level indicator?
Can you post a copy of your circuit please?
Tom.... :slight_smile:
Hi TomGeorge,
I have KCMR (Slave) , RS485 to TTL converter and esp32 board. I connect A & B of "KCMR- 84ARS Digital Level Indicator"to A and B of RS485 to TTL converter then TTL have 4 pins DI,DE,RE and RO which connects to esp32 as write in code.
Hi DrDiettrich,
Can you please elaborate this "switching the RS-485 half-duplex direction. After a command is sent to the device, the direction has to be reversed so that the device can send to the controller" further
Thanking you in advance
Sorry, my English is not good enough for better explanation.
You better use full duplex RS-232 if available with your specific device.
Hi DrDiettrich,
I would highly appreciate you if you will guide me in this regards.
You better start coding with simpler sensors, which should come with circuit diagrams, libraries and example code.
DrDiettrich,
I already read "holding Register" of different Sensors with this code by using proper register mapping and accomplished with it.
Hi Tom,
Yes I have the Modbus option with my Level Indicator. Kindly do provide any solution regarding this. I am be very thankful to you.
Hello Everyone,
Kindly do assist/support me in this regard. Thanking you:-)
