problem interfacing LCD using I2C bus (Solved :) )
ReSiStAnCe:
The LSB from this byte is the R/W bit and has nothing to do with the adress off the device. You do have to send it though..
It has everything to do with the address value that you send to a library that expects an 8 bit address.
Lets see you use the wire library beginning with the transmission of a 7 bit address followed by the transmission of a single read/write bit.
