problem interfacing LCD using I2C bus (Solved :) )
sushant:
hi,
i was trying to interface 16x2 LCD to the Arduino using I2C bus, but despite all the efforts was unable to Display "Hello world" example.
informations:
  1. i'm using pfc8574AP, the circuit is theone demonstrated herehttp://dangerousprototypes.com/2009/08/13/bus-pirate-hd44780-character-lcd-adapter/
2)A2,A1,A0 is connected to ground .so have assigned the address as 0x38 w.r.t the datasheet
3) have connected pull-down resistors of 4.7K (as per the instruction on various forums)
LiquidCrystal_I2C lcd(0x38,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
When you look at the datasheet http://www.nxp.com/documents/data_sheet/PCF8574.pdf on page 10 you can see that the device-adress is 7 bits long.
Starting from A0,A1 and A2, then 0,0,1,0. So your adress is somewhere between b0100000 and b0100111 or between 0x20 and 0x27.
So if you set A0 - A1 low this is 0x20. You declare it as being 0x38. I assume the comment was not edited by you, so the original code adressed the device with A0 - A1 set high...
