problem interfacing regarding memory by using i2c
I m trying to make fully automatic washing machine without water level sensor. It is pretty simple to put on relays but my programs freeze or behave strangely sometimes. Is it memory issue or program has written in dirty way. The sketch is below. Please help me to fix this issue.
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include <EEPROM.h>
//-- I2C 16x2 LCD Display Support Added!
//-- [LCD : http://ecx.images-amazon.com/images/I/51NJ2CGn63L.jpg ,
//-- I2C Interface : http://ecx.images-amazon.com/images/I/51QKT0ft6RL.jpg]
/////------------------------------------- LCD MODULE INITIALIZATION -----------------------//
#define I2C_ADDR 0x3F // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
/////---------------------------------- END OF LCD MODULE INITIALIZATION -------------------//
//-------- Relay State Setups -------//
#define CLOCKWISE HIGH
#define ANTICLOCKWISE LOW
#define RELAY_ON LOW
#define RELAY_OFF HIGH
// PORTS //
#define MotorPowerPort 2
#define MototrDirectionPort 6
#define WaterFillValvePort 4
#define WaterDrainValvePort 5
#define CONTROL_SWITCH 8
// GLOBAL PROCESS VARIABLES //
double process_start = 0L;
unsigned long process_duration = 0L;
int motor_status = CLOCKWISE;
int process = 0;
String process_name = "";
int process_max = 10;
long millis_padding = 0;
  lcd.begin (16, 2);
  lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
  lcd_cleanPrint("WELCOME!", "");
  lcd_blinkScreen(3);
  processInit();
  if (doProcess())
    processReset();
    lcd_blinkScreen(3);
    lcd_cleanPrint("Wash over!", "");
    delay(3000);
//-------------------------LCD Derived Methods----------------------------------//
void lcdProgressBar(double val,double outof)
void lcd_blinkScreen(int t)
  for (int i = 0; i < t; i++)
    lcd.setBacklight(LOW);
    lcd.setBacklight(HIGH);
void lcd_cleanPrint(String line1, String line2)
  delay(100);
  lcd.clear();
  lcd.home ();
  lcd.setCursor (0, 0);
  lcd.print(line1);
  lcd.setCursor (0, 1);
  lcd.print(line2);
  delay(100);
void lcd_Clean()
  delay(100);
  lcd.clear();
  lcd.home ();
//------------------PROCESS AND OPERATIONS ---------------------------------//
boolean doProcess() //Return is Completed !
  if (process == 0)drainWater(1);
  else if (process == 1)fillWater(5);
  //doSoak(2);
  else if (process == 2)doWash(4000, 10, "WASHING ");
  else if (process == 3)drainWater(2);
  else if (process == 4)fillWater(5);
  else if (process == 5)doWash(5000, 8, "RINSING 1");
  else if (process == 6)drainWater(3);
  else if (process == 7)fillWater(5);
  else if (process == 8)doWash(6000, 7, "RINSING 2");
  else if (process == 9)drainWater(2);
  else if (process == 10)doSpin(3, CLOCKWISE);
  else return true;
  processUpdate();
  return false;
double process_pivot = 0;
void processUpdate()
  double process_current = millis_padded();
  if ((process_current - process_start) >= process_duration)
    process++;
    processReset();
    if ((process_current - process_pivot) > 1000) //If past a minimum of one sec
      //double remain=(process_remain/1000)/60;
      process_pivot = process_current;
      lcd_Clean();
      lcd.print(process_name);
      process_current = (process_current - process_start);
      process_current = process_current / 1000;
      if (process_current >= 60)
        process_current = process_current / 60;
        lcd.print((int)process_current);
        lcd.print("Min");
        lcd.print("Sc");
      lcd.print("/");
      process_current = process_duration / 1000;
        lcd.print("Min");
        lcd.print("Sc");
void processInit()
  pinMode(MotorPowerPort, OUTPUT);
  pinMode(MototrDirectionPort, OUTPUT);
  pinMode(WaterFillValvePort, OUTPUT);
  pinMode(WaterDrainValvePort, OUTPUT);
  pinMode(CONTROL_SWITCH, INPUT_PULLUP);
  process_duration = 0;
  process = 0;
  process_start = millis_padded();
  digitalWrite(MotorPowerPort, RELAY_OFF);
  digitalWrite(MototrDirectionPort, CLOCKWISE);
  digitalWrite(WaterFillValvePort, RELAY_OFF);
  digitalWrite(WaterDrainValvePort, RELAY_OFF);
void processReset()
void setProcessDuration(int mins)
  process_duration = mins2millis(mins);
//---------------------Process In Detail --------------------------------------//
void doWash(int cycle_delay, int time_mins, String title)
  process_name = title;
  setProcessDuration(time_mins);
  if (motor_status == CLOCKWISE)motor_status = ANTICLOCKWISE;
  else motor_status = CLOCKWISE;
  digitalWrite(MotorPowerPort, RELAY_OFF); //TURN OFF MAIN POWER TO MOTOR
  digitalWrite(MototrDirectionPort, motor_status); //SET MOTOR DIRECTION
  digitalWrite(MotorPowerPort, RELAY_ON); //TURN ON MAIN POWER TO MOTOR
  delay(cycle_delay);
void fillWater(int time_mins)
  process_name = "FILLING WATER";
  digitalWrite(WaterFillValvePort, RELAY_ON);
void drainWater(int time_mins)
  process_name = "DRAINING WATER";
  digitalWrite(WaterDrainValvePort, RELAY_ON);
void doSpin(int time_mins, int DIR)
  process_name = "DRY SPINNING";
  delay(3000);
void doSoak(int time_mins)
  process_name = "SOAKING DRESS";
  //JUST WAIT :)
unsigned long mins2millis(int mins)
  return (((unsigned long)mins) * 60 * 1000);
double millis_padded()
  return (millis() + millis_padding);
If you do not operate washing machine motors, does the program still hang?
If you do not operate relays, does the program still hang?
Hanging programs and strange behavior are often caused by EMI and/or poor power and/or inductive kickback from motors and/or relays.
