I'm trying to measure pressure and temperature using SMD500 sensor. I used I2C to communicate method, 2 pins interface. The Connection was set as follows:
- VCC of the SMD500 sensor to 3.3V
- Connect GND to Ground
-Connect SCL to i2c clock - on Arduino Uno Analog 5
-Connect SDA to i2c data - on Arduino Uno Analog 4
The used code for similar sensor is shown below:
#include <Adafruit_BMP085.h>
This is an example for the BMP085 Barometric Pressure & Temp Sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> https://www.adafruit.com/products/391
These pressure and temperature sensors use I2C to communicate, 2 pins
are required to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
// Connect VCC of the BMP085 sensor to 3.3V (NOT 5.0V!)
// Connect GND to Ground
// Connect SCL to i2c clock - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 5
// Connect SDA to i2c data - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 4
// EOC is not used, it signifies an end of conversion
// XCLR is a reset pin, also not used here
Adafruit_BMP085 bmp;
if (!bmp.begin(0x77)) {
Serial.println("Could not find a valid BMP085 sensor, check wiring!");
while (1) {}
Serial.print("Temperature = ");
Serial.print(bmp.readTemperature());
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bmp.readPressure());
Serial.println(" Pa");
// Calculate altitude assuming 'standard' barometric
// pressure of 1013.25 millibar = 101325 Pascal
Serial.print("Altitude = ");
Serial.print(bmp.readAltitude());
Serial.println(" meters");
Serial.print("Pressure at sealevel (calculated) = ");
Serial.print(bmp.readSealevelPressure());
// you can get a more precise measurement of altitude
// if you know the current sea level pressure which will
// vary with weather and such. If it is 1015 millibars
// that is equal to 101500 Pascals.
Serial.print("Real altitude = ");
Serial.print(bmp.readAltitude(101500));
However, the result at the console is illogic:
Temperature = 0.00 *C
Pressure = 235 Pa
Altitude = 30355.89 meters
I looked for solving this problem, I found that the sensor needs master clock input 32768 Hz. However, I don't know how to generate this clock.
Please, help me to solve this problem as soon as possible.
Kindly, find the datasheet for SMD500 sensor.
