Problem interfacing with an 25LC040 EEPROM (SPI)
I'm trying to store and read data from a 25LC040 EEPROM (http://www.c-stamp.com/Documents/Documentation/CS450000d1.pdf).
When I'm trying to read the addresses I'm just getting zeros as output.
I followed along with this tutorial: http://arduino.cc/en/Tutorial/SPIEEPROM.
This is my code:
#define DATAOUT 11 //MOSI
#define DATAIN  12//MISO
#define SPICLOCK  13//sck
#define SLAVESELECT 10//ss
//opcodes
#define WREN  6
#define WRDI  4
#define RDSR  5
#define WRSR  1
#define READ  3
#define WRITE 2
byte eeprom_output_data;
byte eeprom_input_data=0;
byte clr;
int address=0;
//data buffer
char buffer [16];
int a = 2;
void fill_buffer()
  for(int i = 0; i < 16; i++)
    buffer[i] = i;
  pinMode(DATAOUT, OUTPUT);
  pinMode(DATAIN, INPUT);
  pinMode(SPICLOCK, OUTPUT);
  pinMode(SLAVESELECT, OUTPUT);
  digitalWrite(SLAVESELECT, HIGH);
  SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1);
  clr=SPSR;
  clr=SPDR;
  delay(10);
  fill_buffer();
  digitalWrite(SLAVESELECT, LOW);
  spi_transfer(WREN);
  delay(10);
  spi_transfer(WRITE);
  spi_transfer(address);
    spi_transfer(buffer[i]);
  delay(3000);
  Serial.write("done writing \n");
  if(address < 16)
    Serial.print("reading data \n");
    eeprom_output_data = read_eeprom(address);
    Serial.print(eeprom_output_data,DEC);
    Serial.write('\n');
    address++;
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait for the end of the transmission
  return SPDR;                    // return the received byte
byte read_eeprom(int EEPROM_address)
  int data;
  spi_transfer(READ);
  spi_transfer((char)(EEPROM_address));
  data = spi_transfer(0xFF);
  digitalWrite(SLAVESELECT,HIGH);
  return data;
Any help would be very much appreciated.
Nevermind.
I failed to wire the EEPROM correctly... stupid me:).
