Hi All
If anybody could point me in the right direction it would be most helpful.
Here is some info for you to chew over.
Project Info:
Arduino Model: Mega 2560
Purpose in this project: To interput momentary button presses from a custom built steering wheel rim replacement for the Official Xbox 360 Wireless Steering Wheel and output via soldered points on the wheels PCB directly.( A Classic combo button controller hack)
Status: I am at the hardware integration stage EG: Soldering the Arduino Outputs to the physical PCB board.
Problem: When I connect the Arduino I get no feedback from the Xbox that a button press has occurred, for example I have checked everything is working correctly with LEDs and every action is confirmed as working properly.
Where I think the problem may be: I think there could be several possible reasons for the Official Wheel not recognising the button presses on the new custom wheel rim.
1:Voltage is specific( I have tried 5v and 3.3 v with no effect)
2: Could be a grounding issue maybe the controller isn't common ground?
You're advice on how to resolve this issue would be greatly appreciated
I have attached a Photo of the Official Circuit Board to help demystify what I am describing.
Many Thanks
Doc
