Problem interpret result from Exception Decoder
Hello friends. My setup gives me this errormessage:
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x40146d13  PS      : 0x00060430  A0      : 0x80148468  A1      : 0x3ffb1dc0
A2      : 0x00000036  A3      : 0x3ffb1e5c  A4      : 0x3ffb1e58  A5      : 0x00000000
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x80146d0c  A9      : 0x3ffb1da0
A10     : 0x00000000  A11     : 0x00000000  A12     : 0x3ffcfb84  A13     : 0x00000000
A14     : 0x00000000  A15     : 0x3ffb0060  SAR     : 0x0000000a  EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000002c  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
Backtrace: 0x40146d13:0x3ffb1dc0 0x40148465:0x3ffb1e30 0x400d6e03:0x3ffb1e50 0x400db99e:0x3ffb1e90 0x400dee89:0x3ffb1ee0 0x400d37d6:0x3ffb1f00 0x400f5e15:0x3ffb1fb0 0x4008bc15:0x3ffb1fd0
To find out whats going on i installed and used the expection decoder
This was the result:
Decoding 8 results
0x40146d13: lwip_accept at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/api/sockets.c line 3524
0x40148465: lwip_accept_r at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/api/sockets.c line 3524
0x400d6e03: WiFiServer::available() at C:\Users\manue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi\src/WiFiServer.cpp line 120
0x400db99e: WebServer::handleClient() at C:\Users\manue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WebServer\src/WebServer.cpp line 276
0x400dee89: AutoConnect::handleClient() at C:\Users\manue\Documents\Arduino\libraries\AutoConnect\src/AutoConnect.cpp line 505
0x400d37d6: loop() at C:\Users\manue\Desktop\IDS_GSM_MODUL_ARDUINO/IDS_GSM_MODUL_ARDUINO.ino line 935
0x400f5e15: loopTask(void*) at C:\Users\manue\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32/main.cpp line 19
0x4008bc15: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 355 (discriminator 1)
I am kinda lost how to interpret the result. Does anyone see more?
Thank you
Your sketch died while trying to accept an incoming TCP connection.
