Problem IR remote
#include <IRremote.h>
int RECV_PIN = 3;
IRrecv irrecv(RECV_PIN);
decode_results results;
int RED = 9;
int BLUE = 10;
int GREEN = 11;
int n;
#define FADESPEED 8
  pinMode(BLUE, OUTPUT);
  pinMode(RED, OUTPUT);
  pinMode(GREEN, OUTPUT);
  irrecv.blink13(true);
  irrecv.enableIRIn();
   if (irrecv.decode(&results))
    Serial.print("results value is ");
    Serial.print(results.value, HEX);
    Serial.print(", bits is ");
    Serial.print(results.bits);
    Serial.print(", decode_type is ");
    Serial.println(results.decode_type);
    irrecv.resume();
  switch(results.value)
    case 0xF740BF:
Fade7();
case 0xFC4BF
digitalWrite(RED,LOW);
digitalWrite(BLUE,LOW);
digitalWrite(GREEN,LOW);
void Fade7()
  int r, g, b;
  // fade from blue to violet
  for (r = 0; r < 256; r++) {
    analogWrite(RED, r);
    delay(FADESPEED);
//    irrecv.resume();
  // fade from violet to red
  for (b = 255; b > 0; b--) {
    analogWrite(BLUE, b);
    delay(FADESPEED);
  // fade from red to yellow
  for (g = 0; g < 256; g++) {
    analogWrite(GREEN, g);
    delay(FADESPEED);
  // fade from yellow to green
  for (r = 255; r > 0; r--) {
    delay(FADESPEED);
  // fade from green to teal
  for (b = 0; b < 256; b++) {
    delay(FADESPEED);
  // fade from teal to blue
  for (g = 255; g > 0; g--) {
    delay(FADESPEED);
cannot loop FADE7();
The syntax is :
Switch(whatever){
     case case1: {
        do case1_stuff:
     break:
     case case2: {
         do case2_stuff:
   etc
allanhurst:
The syntax is :
 break:
Oh, no it isn't.
same problem cannot switch to other case when remote is press
Sorry - got my ':'s and ';'s misspelt...
Allan
