Problem IR to control my Thermopump
I am new in arduino but I've already sucessfully make work test project using IR such as reading the code of my samsung tv remote with
or command my tv using an ir led.
So I tried the next level for me which is: command my thermopump using IR. I have a fan I can command with a remote (YAN1F1F model).
Using the same sensor I can read code from the remote: according to IRremote lib it is a nec protocol and according to IRLib it is unknown.
Still according the lib I have diffrent reading results.
In one librabry it seems the 2nd code is FFFFFFFF (repeat code is I understand well) or it can be 2 codes such :
3259160A then 32591606 or
3259160A and FFFFFFFF then 32591606 and FFFFFFFF
I tried to send these code using my IR led but it is not working. I tried different code I found on the net but my fan does not seem to receive the code.
I check the ir led with a camera and it is blinink the the code is sent.
Finaly i tried the following code which is supposed to record the row code when I press a button and send it. But it is still not working.
/* Example program for from IRLib – an Arduino library for infrared encoding and decoding
 * Version 1.5  June 2014
 * Copyright 2014 by Chris Young http://cyborg5.com
 * Based on original example sketch for IRremote library
 * Version 0.11 September, 2009
 * Copyright 2009 Ken Shirriff
 * http://www.righto.com/
 * IRrecord: record and play back IR signals
 * An IR detector/demodulator must be connected to the input RECV_PIN.
 * An IR LED must be connected to the appropriate pin.(See IRLibTimer.h) for your
 * machine's timers and erupts.
 * Record a value by pointing your remote at the device then send any character
 * from the serial monitor to send the recorded value.
 * Also demonstrates how to use toggle bits which must be controlled outside
 * the library routines.
 * The logic is:
 * If an IR code is received, record it.
 * If a serial character is received, send the IR code.
#include <IRLib.h>
int RECV_PIN = 11;
IRrecv My_Receiver(RECV_PIN);
IRdecode My_Decoder;
IRsend My_Sender;
 * Because this version of the library separated the receiver from the decoder,
 * technically you would not need to "store" the code outside the decoder object
 * for this overly simple example. All of the details would remain in the object.
 * However we are going to go ahead and store them just to show you how.
// Storage for the recorded code
IRTYPES codeType;          // The type of code
unsigned long codeValue;   // The data bits if type is not raw
int codeBits;              // The length of the code in bits
// These values are only stored if it's an unknown type and we are going to use
// raw codes to resend the information.
unsigned int rawCodes[RAWBUF]; // The durations if raw
int rawCount;                   //The number of interval samples
bool GotOne, GotNew;
  GotOne=false; GotNew=false;
  codeType=UNKNOWN;
  codeValue=0;
  delay(2000);while(!Serial);//delay for Leonardo
  Serial.println(F("Send a code from your remote and we will record it."));
  Serial.println(F("Type any character and press enter. We will send the recorded code."));
  My_Receiver.enableIRIn(); // Start the receiver
// Stores the code for later playback
void storeCode(void) {
  GotNew=true;
  codeType = My_Decoder.decode_type;
  if (codeType == UNKNOWN) {
    Serial.println("Received unknown code, saving as raw");
    // To store raw codes:
    // Drop first value (gap)
    // As of v1.3 of IRLib global values are already in microseconds rather than ticks
    // They have also been adjusted for overreporting/underreporting of marks and spaces
    rawCount = My_Decoder.rawlen-1;
    for (int i = 1; i <=rawCount; i++) {
      rawCodes[i - 1] = My_Decoder.rawbuf[i];
    My_Decoder.DumpResults();
    codeType=UNKNOWN;
  else {
    Serial.print(F("Received "));
    Serial.print(Pnames(codeType));
    if (My_Decoder.value == REPEAT) {
      // Don't record a NEC repeat value as that's useless.
      Serial.println(F("repeat; ignoring."));
     else {
       codeValue = My_Decoder.value;
       codeBits = My_Decoder.bits;
     Serial.print(F(" Value:0x"));
     Serial.println(My_Decoder.value, HEX);
void sendCode(int repeat) {
  if(codeType== UNKNOWN) {
    // Assume 38 KHz
    My_Sender.IRsendRaw::send(rawCodes,rawCount,38);
    Serial.println(F("Sent raw"));
    return;
  if( !GotNew ) {//We've already sent this so handle toggle bits
    if (codeType == RC5) {
      codeValue ^= 0x0800;
    else if (codeType == RC6) {
      codeValue ^= 0x10000;
  GotNew=false;
  My_Sender.send(codeType,codeValue,codeBits);
  Serial.print(F("Sent "));
  Serial.println(codeValue, HEX);
//  if (Serial.read() != -1) {
    if(GotOne) {
      sendCode(0);
      delay(250);
      My_Receiver.enableIRIn(); // Re-enable receiver
  else if (My_Receiver.GetResults(&My_Decoder)) {
    My_Decoder.decode();
    GotOne=true;
    storeCode();
    My_Receiver.resume();
If anyone has an idea to help me.
Thanks
Post the output from this sketch & I will examine it for you..
Air Conditioners: Recording long Infrared Remote control signals with Arduino
Usually I keep pressing the button I want the code from on my IR remote while it's facing the IR receiver then I choose the most recurring IR code
e.g. press 1 0x12345678
press 2 0x12345678
press 3 0x12345678
press 4 0x1234IWER
press 5 0x1234IWER
press 6 0x1234HJSA
After pressing the Login button 6 times I get the above information in my serial monitor. I look at the Information and I see 0x12345678 is recurring most often. So i'll use 0x12345678 as my IR code in the sketch for the Login signal.
From what I understand you could be getting different IR codes because the light in the room you are operating in is interfering with the IR waves. Perhaps try switching the lights off when you record the IR signal.
Also try to place Samsung remote IR LED as close as possible to the IR receiving module.
hope this helps a bit.
