Problem is robot will avoid the obstacle, but after that no forward again
#define trigPin 12
#define echoPin 13
#define ir1 7
#define ir2 6
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(ir1, INPUT);
pinMode(ir2,INPUT);
int duration, distance;
int flag,val1,val2;
val1=digitalRead(ir1);
val2=digitalRead(ir2);
Serial.println(val1);
Serial.println(val2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance >= 200 || distance <= 0){
Serial.println("Out of range");
else {
Serial.print(distance);
Serial.println(" cm");
delay(100);
if (distance >=20)
delay(100);
Serial.println("forward");
digitalWrite(8,HIGH);
digitalWrite(9,LOW);
digitalWrite(10,HIGH);
digitalWrite(11,LOW);
delay(100);
if (distance<=20)
if (val1==1 )
Serial.print("turn right");
digitalWrite(8,LOW);
delay(200);
if (val2==1)
Serial.print("turn left");
digitalWrite(10,LOW);
delay(200);
if(distance<=10)
Serial.print("rearrange back");
digitalWrite(9,HIGH);
digitalWrite(11,HIGH);
delay(200);
Serial.print("rearranged left");
delay(200);
if (distance<=20)
Serial.print("Algorithum");
Serial.print("free right");
if(val2==0)
Serial.print("smart adjust");
delay(300);
Welcome, your topic has been moved.
Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
Please edit your post and apply code tags; next save your post. The use of code tags is described in How to get the best out of this forum which might contain some more useful information.
I see that somewhere in that gibberish you missed telling it to start to again. Also an annotated schematic is a lot better then a list of pins that really does not say a lot.
