Problem is with the PS2Mouse example from Playground
Hello!
Okay in this case I went to the Playground location here: http://playground.arduino.cc/ComponentLib/Ps2mouse
And retrieved the library file from it. I then installed its contents in the library folder for the Arduino and attempted to try its example.
Instead using this code:
#include "ps2dev.h"
PS2dev mouse(3,2); // 2 data 3clock
char buttons[3] = {0,0,0};
int delta_x = 0;
int delta_y = 0;
//we start off not enabled
int enabled =0;
//ack a host command
void ack() {
  while(mouse.write(0xFA));
void write_packet() {
  char overflowx =0;
  char overflowy =0;
  char data[3];
  int x,y;
  if (delta_x > 255) {
    overflowx =1;
    x=255;
  if (delta_x < -255) {
    overflowx = 1;
    x=-255;
  if (delta_y > 255) {
    overflowy =1;
    y=255;
  if (delta_y < -255) {
    overflowy = 1;
    y=-255;
  data[0] = ((overflowy & 1) << 7) |
    ( (overflowx & 1) << 6) |
    ( (((delta_y &0x100)>>8) & 1) << 5) |
    ( ( ((delta_x &0x100)>>8)& 1) << 4) |
    ( ( 1) << 3) |
    ( ( buttons[1] & 1) << 2) |
    ( ( buttons[2] & 1) << 1) |
    ( ( buttons[0] & 1) << 0) ;
  data[1] = delta_x & 0xff;
  data[2] = delta_y & 0xff;
  mouse.write(data[0]);
  mouse.write(data[1]);
  mouse.write(data[2]);
  delta_x = 0;
  delta_y = 0;
int mousecommand(int command) {
  unsigned char val;
  //This implements enough mouse commands to get by, most of them are
  //just acked without really doing anything
  switch (command) {
  case 0xFF: //reset
    ack();
    //the while loop lets us wait for the host to be ready
    while(mouse.write(0xAA)!=0);
    while(mouse.write(0x00)!=0);
  case 0xFE: //resend
    ack();
  case 0xF6: //set defaults
    //enter stream mode
    ack();
  case 0xF5:  //disable data reporting
    //FM
    ack();
  case 0xF4: //enable data reporting
    //FM
    enabled = 1;
    ack();
  case 0xF3: //set sample rate
    ack();
    mouse.read(&val); // for now drop the new rate on the floor
    //      Serial.println(val,HEX);
    ack();
  case 0xF2: //get device id
    ack();
    mouse.write(00);
  case 0xF0: //set remote mode
    ack();
  case 0xEE: //set wrap mode
    ack();
  case 0xEC: //reset wrap mode
    ack();
  case 0xEB: //read data
    ack();
    write_packet();
  case 0xEA: //set stream mode
    ack();
  case 0xE9: //status request
    ack();
    //      send_status();
  case 0xE8: //set resolution
    ack();
    mouse.read(&val);
    ack();
  case 0xE7: //set scaling 2:1
    ack();
  case 0xE6: //set scaling 1:1
    ack();
int xcenter ;
int ycenter;
int xsum = 0;
int ysum = 0;
  unsigned char val;
  // send the mouse start up
  unsigned char  c;
  if( (digitalRead(3)==LOW) || (digitalRead(2) == LOW)) {
    while(mouse.read(&c)) ;
    mousecommand(c);
  if (enabled) {
    // move the mouse diagonally
    delta_x = 1;
    delta_y = 1;
    write_packet()  ;
  delay(50);
And naturally an error surfaces:
In file included from ps2_mouse.pde:2:
C:\Users\GCL.CMDRSKYWALKER\Documents\Arduino\libraries\ps2dev/ps2dev.h:12:24: error: WConstants.h: No such file or directory
I had thought all of the W* headers were either fixed or removed?
They were. So, when you see a library that still uses one, you know it hasn't been updated for 1.0+ use.
Instead of starting another new thread, learn how to search for one of the bazillion posts about how to upgrade the library.
PaulS:
Hello! Now what are you thinking of? I really do not have any idea as to what you're getting at this time. I didn't run off and start another thread, I started one on a completely unrelated subject. And wrote an appropriate reply.
The subject of searching and properly doing so for posts on how to upgrade a library should have been supplied not a response from someone who probably collided with the same problem and was able to fix it which was stated improperly, instead of that preposterous response.
Hello!
Nick G, I don’t know if you’re following the PS2Mouse example one, but both of the examples that I cited here and in the other one, on the keyboard problem are now fixed.
Oddly enough it was the same <BLEEP!> problem exactly.
