Problem learning microstep program
Hi Guys,
I’m learning stepper motor with microstep driver program.
Here is my program.
#include <AccelStepper.h>
AccelStepper stepper(AccelStepper::DRIVER, 2, 3); // 2-PUL,3-DIR
stepper.setAcceleration(10000);
stepper.setCurrentPosition(0);
stepper.setMaxSpeed(40000);
long current_position;
current_position = stepper.currentPosition();
if(current_position==0){
stepper.moveTo(-1000);
if (current_position==-1000){
stepper.moveTo(-2000);
else if (current_position==-2000){
stepper.moveTo(0);
stepper.run();
Well my question is, how can i run the stepper from 0 to -1000 and then to -2000. Also from -2000 to 0.
If i write the program like that, before the -2000 get to 0, and reach -1000, it will go back to -2000.
Anyway, i hope somebody can help me.
Thanks. :smiley:
Rather than checking if(current_position==0){ etc. you first need to check if the current position has reached its destination. Something like this
if (current_position == destination) {
   if (current_position == 0) {
      destination = -1000;
      stepper.moveTo(destination);
  if (current_position == -1000) {
      destination = -2000;
  // etc
…R
Hi Mr.Robin,
Thanks for your reply.
Anyway how should i declare the destination?
Can i use this?
// Define a stepper and the pins it will use
AccelStepper stepper(AccelStepper::DRIVER, 2, 3); // 13-PUL,12-DIR
stepper.setAcceleration(30000);
stepper.setMaxSpeed(10000);
long destination;
if (current_position == -2000) {
destination = -3000;
stepper.run();
But, the stepper motor run just once, from 0 to -3000.
the 0 to -1000, and -1000 to -2000 didn’t work.
Thanks!
the 0 to -1000, and -1000 to -2000 didn't work.
Are you sure? How do you know?
Maybe it would be clearer if you make the delay()s longer
If you want the sequence to repeat you need a test for current_position == -3000
...R
