Just tried to keep it clean an short. Here is the full code, the MPU6050 code is from Jeff Rowberg, as I mentioned before.
Device B:
#include "I2Cdev.h"
#include "MPU6050.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
double ax_ms, ay_ms, az_ms; //m pro sekunde²
String zeit = String();
String deviceB = String();
String left_dev = String();
const byte numChars = 100;
char receivedChars[numChars];
boolean newData = false;
// uncomment "OUTPUT_READABLE_ACCELGYRO" if you want to see a tab-separated
// list of the accel X/Y/Z and then gyro X/Y/Z values in decimal. Easy to read,
// not so easy to parse, and slow(er) over UART.
#define OUTPUT_READABLE_ACCELGYRO
// uncomment "OUTPUT_BINARY_ACCELGYRO" to send all 6 axes of data as 16-bit
// binary, one right after the other. This is very fast (as fast as possible
// without compression or data loss), and easy to parse, but impossible to read
// for a human.
//#define OUTPUT_BINARY_ACCELGYRO
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
// initialize device
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
accelgyro.setXAccelOffset(-3291);
accelgyro.setYAccelOffset(802);
accelgyro.setZAccelOffset(659);
accelgyro.setXGyroOffset(122);
accelgyro.setYGyroOffset(-23);
accelgyro.setZGyroOffset(-7);
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// these methods (and a few others) are also available
//accelgyro.getAcceleration(&ax, &ay, &az);
//accelgyro.getRotation(&gx, &gy, &gz);
#ifdef OUTPUT_READABLE_ACCELGYRO
// display tab-separated accel/gyro x/y/z values
ax_ms=98.1*ax/16384;
ay_ms=98.1*ay/16384;
az_ms=98.1*az/16384;
ax_ms=ax_ms/10;
ay_ms=ay_ms/10;
az_ms=az_ms/10;
zeit = String(millis());
deviceB= String("\t R: \t" + zeit + "\t" + ax_ms + "\t" + ay_ms + "\t" + az_ms);
#endif
#ifdef OUTPUT_BINARY_ACCELGYRO
Serial.print(millis());
Serial.write((uint8_t)(ax >> 8)); Serial.write((uint8_t)(ax & 0xFF));
Serial.write((uint8_t)(ay >> 8)); Serial.write((uint8_t)(ay & 0xFF));
Serial.write((uint8_t)(az >> 8)); Serial.write((uint8_t)(az & 0xFF));
Serial.write((uint8_t)(gx >> 8)); Serial.write((uint8_t)(gx & 0xFF));
Serial.write((uint8_t)(gy >> 8)); Serial.write((uint8_t)(gy & 0xFF));
Serial.write((uint8_t)(gz >> 8)); Serial.write((uint8_t)(gz & 0xFF));
#endif
recvWithStartEndMarkers();
showNewData();
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '\n';
char rc;
// if (Serial.available() > 0) {
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void showNewData() {
if (newData == true) {
Serial.println(receivedChars + deviceB);
newData = false;
Serial.flush();
Device A:
#include "I2Cdev.h"
#include "Wire.h"
#endif
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
int16_t gx, gy, gz;
String deviceA = String();
float zeit2;
String stringData = String();
// for a human.
#define LED_PIN 13
bool blinkState = false;
pinMode(3, OUTPUT);
Wire.begin();
#endif
//Serial.println("Initializing I2C devices...");
ax_ms = 98.1 * ax / 16384;
ay_ms = 98.1 * ay / 16384;
az_ms = 98.1 * az / 16384;
ax_ms = ax_ms / 10;
ay_ms = ay_ms / 10;
az_ms = az_ms / 10;
deviceA = String("L:\t" + zeit + "\t" + ax_ms + "\t" + ay_ms + "\t" + az_ms);
Serial.print("<");
delay(18);
Serial.print(deviceA);
delay(18);
Serial.print("\n");
delay(18);
//Serial.flush();
Serial.end();
#endif
Serial.print("L: "); Serial.print("\t");
Serial.print(millis()); Serial.print("\t");
#endif
I use the Method "recvWithStartEndMarkers" to recognize the start and the end of an incoming Serial Line.
