Problem loading to board
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno WiFi"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jimmy\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jimmy\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jimmy\Documents\Arduino\libraries -fqbn=arduino:avr:unowifi -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\jimmy\AppData\Local\Temp\arduino_build_351501 -warnings=none -build-cache C:\Users\jimmy\AppData\Local\Temp\arduino_cache_444426 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\jimmy\AppData\Local\Temp\arduino_modified_sketch_340585\BareMinimum.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jimmy\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jimmy\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jimmy\Documents\Arduino\libraries -fqbn=arduino:avr:unowifi -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\jimmy\AppData\Local\Temp\arduino_build_351501 -warnings=none -build-cache C:\Users\jimmy\AppData\Local\Temp\arduino_cache_444426 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\jimmy\AppData\Local\Temp\arduino_modified_sketch_340585\BareMinimum.ino
Using board 'unowifi' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\sketch\\BareMinimum.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\sketch\\BareMinimum.ino.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_DEV_ED -DARDUINO_ARCH_AVR -DESP_CH_UART -DESP_CH_UART_BR=19200 "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\sketch\\BareMinimum.ino.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\sketch\\BareMinimum.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\jimmy\AppData\Local\Temp\arduino_cache_444426\core\core_arduino_avr_unowifi_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501\\sketch\\BareMinimum.ino.cpp.o" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/..\\arduino_cache_444426\\core\\core_arduino_avr_unowifi_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/BareMinimum.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/BareMinimum.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_351501/BareMinimum.ino.elf"
Sketch uses 724 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xce
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xce
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xce
What board are you trying to load your code into?
its a uno with wifi
is anything connected to the arduino
We need you to be more specific. There are several things that might be referred to as an "uno with wifi", and the answer is different depending on which of those things you have.
Please post a link to where you bought your board from.
and we need to know if anything is connected and when you bought it
