Hello everyone, for the past few days I have been trying to program my 53 led cube with little to no succes. After soldering the cube I have tested everything to see if there is no shorting in the circuit everything was good. I then attached cables to the layers and the columns of the cube and i prototyped the control circuit on a bread board. I am using 6 74hc595n shift registers with 10nf capacitors across their vcc and ground, 5 registers for each row and 1 for the layers. The layers sink to ground through 5 2n3906 transistors. For the 595's, master reset is pulled high while the output enable is pulled low, the register and latch clocks are the same for each one and i have daisy chained each one, pin 9 from the first one goes into pin 14 of the second and so on. I am powering everything from a 5V 500 mA supply (which is an old phone charger, I think it may be relevant).
For the code part of things, i have tried to make them work using the SPI library, but everything i tried failed. There is one piece of code that has worked for me, demonstarting that multiplexing works, but if i try to modify anything starting from that piece of code I get random leds turning on or no leds at all.
#define latch 8 //red
#include <SPI.h>
uint8_t cube[5][5];
int grow=0;
int looplimit=600;
int deltime=2;
loading = true;
SPI.begin();
SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
int i;
lightCube();
renderCube();
void lightCube() {
for (uint8_t i = 0; i < 5; i++) {
for (uint8_t j = 0; j < 5; j++) {
cube[i][j] = 0B11111;
void clearCube() {
cube[i][j] = 0;
void renderCube() {
digitalWrite(latch, LOW);
SPI.transfer(0x01 << i);
//digitalWrite(latch, HIGH);
//digitalWrite(latch, LOW);
SPI.transfer(cube[i][j]);
delay(deltime);
grow++;
if(grow==looplimit){
deltime+=10;
grow=0;
if(looplimit>1)
looplimit=looplimit/2;
One thing i noticed with the code is that only the first row of the matrix cube[][] is taken into consideration, me giving values to cube[1][3] or cube[4][0] will not turn on any led.
I also tried to swap out the 3906 for a 3904 which would heat up the last shift register, and an IRF3025 MOSFET to no succes, same result.
In conclusion my questions are:
- Is my code incorrect or is it a hardware issue?(not using correct parts, something is not tied well, etc)
- What is the difference between 74hc595 and 74hc595n as I didn't find an answer online.
