Hi everyone,
I am trying to create a multiple sensor with audio and I am using a Teensy 4.1 with Audio shield, a ECG AD8232 and the accelerometer LIS3DH. I have a main code B3_V2.ino that posses numerous class (Sensors,LIS3DH, AudioShield etc.) When I try to compile, the accelerometer can not initialize. But when I test the example code provided by the library, it works fine. I do not understand why and I suppose it is due to library management but I have upload the library and the rest of the file are as presented below
and my code for the accelerometer :
#include "Arduino.h"
#include "LIS3DH.h"
// Used for software SPI
#define LIS3DH_CLK 27
#define LIS3DH_MISO 39
#define LIS3DH_MOSI 26
// Used for hardware & software SPI
#define LIS3DH_CS 37
// software SPI
Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
LIS3DH::LIS3DH()
Serial.println("LIS3DH test!");
if (!lis.begin(0x18))
{ // change this to 0x19 for alternative i2c address
Serial.println("Couldnt start LIS3DH");
while (1)
yield();
// lis.setDataRate(LIS3DH_DATARATE_50_HZ);
Serial.print("Data rate set to: ");
switch (lis.getDataRate())
case LIS3DH_DATARATE_1_HZ:
Serial.println("1 Hz");
case LIS3DH_DATARATE_10_HZ:
Serial.println("10 Hz");
case LIS3DH_DATARATE_25_HZ:
Serial.println("25 Hz");
case LIS3DH_DATARATE_50_HZ:
Serial.println("50 Hz");
case LIS3DH_DATARATE_100_HZ:
Serial.println("100 Hz");
case LIS3DH_DATARATE_200_HZ:
Serial.println("200 Hz");
case LIS3DH_DATARATE_400_HZ:
Serial.println("400 Hz");
case LIS3DH_DATARATE_POWERDOWN:
Serial.println("Powered Down");
case LIS3DH_DATARATE_LOWPOWER_5KHZ:
Serial.println("5 Khz Low Power");
case LIS3DH_DATARATE_LOWPOWER_1K6HZ:
Serial.println("16 Khz Low Power");
xvar = 0;
yvar = 0;
zvar = 0;
void LIS3DH::acquire()
lis.read();
// Serial.print("fin LIS3DH : ");
// Serial.println(micros());
sensors_event_t event;
lis.getEvent(&event);
xvar = event.acceleration.x;
yvar = event.acceleration.y;
zvar = event.acceleration.z;
