Problem mangled screen Nano 33 BLE Sense & OLED 1,5" RGB (Wondershare alike)
Hello, Have a screen problem, please help me with a pinout or some help with code, maybe I must put #define SPI_HAS_TRANSACTIONS 1
and if so how and where, then modifiy my code, Thanks.
Dubravko
code is: Adafruit_1351_test
pins:
SCLK_PIN 13
MOSI_PIN 11
DC_PIN 9
CS_PIN 10
RST_PIN 8
or should I use left side of board other 2 pins: SDA & SCL and how hook to oled
pics:
  This is a example sketch demonstrating graphic drawing
  capabilities of the SSD1351 library for the 1.5"
  and 1.27" 16-bit Color OLEDs with SSD1351 driver chip
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/1431
  ------> http://www.adafruit.com/products/1673
  If you're using a 1.27" OLED, change SCREEN_HEIGHT to 96 instead of 128.
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
  The Adafruit GFX Graphics core library is also required
  https://github.com/adafruit/Adafruit-GFX-Library
  Be sure to install it!
// SPI define
//#define SPI_HAS_TRANSACTION 1
// Screen dimensions
#define SCREEN_WIDTH  128
#define SCREEN_HEIGHT 128 // Change this to 96 for 1.27" OLED.
// You can use any (4 or) 5 pins
#define SCLK_PIN 13
#define MOSI_PIN 11
#define DC_PIN   9
#define CS_PIN   10
#define RST_PIN  8
// Color definitions
#define	BLACK           0x0000
#define	BLUE            0x001F
#define	RED             0xF800
#define	GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1351.h>
#include <SPI.h>
// Option 1: use any pins but a little slower
//Adafruit_SSD1351 tft = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, CS_PIN, DC_PIN, //MOSI_PIN, SCLK_PIN, RST_PIN);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
Adafruit_SSD1351 tft = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, CS_PIN, DC_PIN, RST_PIN);
float p = 3.1415926;
void setup(void) {
//  #ifdef SPI_HAS_TRANSACTION
//  SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0));
//  #endif
  Serial.print("hello!");
  tft.begin();
  Serial.println("init");
  // You can optionally rotate the display by running the line below.
  // Note that a value of 0 means no rotation, 1 means 90 clockwise,
  // 2 means 180 degrees clockwise, and 3 means 270 degrees clockwise.
  //tft.setRotation(1);
  // NOTE: The test pattern at the start will NOT be rotated!  The code
  // for rendering the test pattern talks directly to the display and
  // ignores any rotation.
  uint16_t time = millis();
  tft.fillRect(0, 0, 128, 128, BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  lcdTestPattern();
  tft.invert(true);
  delay(100);
  tft.invert(false);
  delay(100);
  tft.fillScreen(BLACK);
  testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", WHITE);
  // tft print function!
  tftPrintTest();
  //a single pixel
  tft.drawPixel(tft.width()/2, tft.height()/2, GREEN);
  // line draw test
  testlines(YELLOW);
  // optimized lines
  testfastlines(RED, BLUE);
  testdrawrects(GREEN);
  testfillrects(YELLOW, MAGENTA);
  testfillcircles(10, BLUE);
  testdrawcircles(10, WHITE);
  testroundrects();
  testtriangles();
  Serial.println("done");
void testlines(uint16_t color) {
   for (uint16_t x=0; x < tft.width()-1; x+=6) {
     tft.drawLine(0, 0, x, tft.height()-1, color);
   for (uint16_t y=0; y < tft.height()-1; y+=6) {
     tft.drawLine(0, 0, tft.width()-1, y, color);
     tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
     tft.drawLine(tft.width()-1, 0, 0, y, color);
     tft.drawLine(0, tft.height()-1, x, 0, color);
     tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
     tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
     tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
  tft.setCursor(0,0);
  tft.setTextColor(color);
  tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
   for (uint16_t y=0; y < tft.height()-1; y+=5) {
     tft.drawFastHLine(0, y, tft.width()-1, color1);
   for (uint16_t x=0; x < tft.width()-1; x+=5) {
     tft.drawFastVLine(x, 0, tft.height()-1, color2);
void testdrawrects(uint16_t color) {
 for (uint16_t x=0; x < tft.height()-1; x+=6) {
   tft.drawRect((tft.width()-1)/2 -x/2, (tft.height()-1)/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
 for (uint16_t x=tft.height()-1; x > 6; x-=6) {
   tft.fillRect((tft.width()-1)/2 -x/2, (tft.height()-1)/2 -x/2 , x, x, color1);
   tft.drawRect((tft.width()-1)/2 -x/2, (tft.height()-1)/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=radius; x < tft.width()-1; x+=radius*2) {
    for (uint8_t y=radius; y < tft.height()-1; y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=0; x < tft.width()-1+radius; x+=radius*2) {
    for (uint8_t y=0; y < tft.height()-1+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
void testtriangles() {
  int color = 0xF800;
  int t;
  int w = tft.width()/2;
  int x = tft.height();
  int y = 0;
  int z = tft.width();
  for(t = 0 ; t <= 15; t+=1) {
    tft.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  int color = 100;
  int x = 0;
  int y = 0;
  int w = tft.width();
  int h = tft.height();
  for(int i = 0 ; i <= 24; i++) {
    tft.drawRoundRect(x, y, w, h, 5, color);
    x+=2;
    y+=3;
    w-=4;
    h-=6;
    color+=1100;
    Serial.println(i);
void tftPrintTest() {
  tft.setCursor(0, 5);
  tft.setTextColor(RED);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(YELLOW);
  tft.setTextSize(2);
  tft.setTextColor(BLUE);
  tft.setTextSize(3);
  tft.print(1234.567);
  delay(1500);
  tft.setTextColor(WHITE);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.setTextColor(GREEN);
  tft.print(p, 6);
  tft.println(" Want pi?");
  tft.println(" ");
  tft.print(8675309, HEX); // print 8,675,309 out in HEX!
  tft.println(" Print HEX!");
  tft.println(" ");
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setTextColor(MAGENTA);
  tft.print(millis() / 1000);
  tft.print(" seconds.");
void mediabuttons() {
 // play
  tft.fillRoundRect(25, 10, 78, 60, 8, WHITE);
  tft.fillTriangle(42, 20, 42, 60, 90, 40, RED);
  // pause
  tft.fillRoundRect(25, 90, 78, 60, 8, WHITE);
  tft.fillRoundRect(39, 98, 20, 45, 5, GREEN);
  tft.fillRoundRect(69, 98, 20, 45, 5, GREEN);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, BLUE);
  delay(50);
  // pause color
  tft.fillRoundRect(39, 98, 20, 45, 5, RED);
  tft.fillRoundRect(69, 98, 20, 45, 5, RED);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, GREEN);
    @brief  Renders a simple test pattern on the screen
void lcdTestPattern(void)
  static const uint16_t PROGMEM colors[] =
    { RED, YELLOW, GREEN, CYAN, BLUE, MAGENTA, BLACK, WHITE };
  for(uint8_t c=0; c<8; c++) {
    tft.fillRect(0, tft.height() * c / 8, tft.width(), tft.height() / 8,
      pgm_read_word(&colors[c]));
This is the item - OLED
https://www.ebay.co.uk/itm/293976369818
Welcome to the forum.
Can you please modify your original post to ensure the source code is in a single box. It should look like this.
// Your example source code
You need three ' at the beginning and end in the edit window? When you click on this icon </> you get.
type or paste code here
This ensures we can get all the source code. Right now if you copy the code there are invisible characters that prevent successful compilation and parts might be missing.
Also add images to your post and not from external pages. People here tend to avoid downloading files from other sources. Datasheets links on manufacturer sites are OK.
