Problem Midi Input Software With Hiduino And Mega2560
Dear Friend,
I have a big problem…I don’t understand… i have flashed ok my arduino mega 2560 with my program test for output midi…work…i have make some button to control reason5…it’s ok…but when i try to receive from computer to arduino via hiduino to turn on some leds to indicate the notes playing don’t work …do you know this problem??
Can somebody help me please??
i have tryed this code but without success.
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial, MIDI);
// i have tryed also  MIDI_CREATE_INSTANCE(HardwareSerial, Serial2, MIDI);
// i have tryed also  MIDI_CREATE_INSTANCE();
// This example shows the old way of checking for input messages.
// It's simpler to use the callbacks now, check out the dedicated example.
#define LED 13                   // LED pin on Arduino Uno
void BlinkLed(byte num)         // Basic blink function
    for (byte i=0;i<num;i++)
        digitalWrite(LED,HIGH);
        delay(50);
        digitalWrite(LED,LOW);
        delay(50);
    pinMode(LED, OUTPUT);
    MIDI.begin();           // Launch MIDI, by default listening to channel 1.
    if (MIDI.read())                // Is there a MIDI message incoming ?
        switch(MIDI.getType())      // Get the type of the message we caught
            case midi::ProgramChange:       // If it is a Program Change,
                BlinkLed(MIDI.getData1());  // blink the LED a number of times
                                            // correponding to the program number
                                            // (0 to 127, it can last a while..)
            // See the online reference for other message types
            default:
Thanks in advance,
Lestroso :confused:
