Problem mit Sketch für Uno
Hallo liebe Gemeinde
Ich habe kürzlich einen Sketch für ein Laser Tag Game (Infrarot) versucht so zu erweitern, dass ein Treffer dem Spieler per Funk (HC-12 module) mitgeteilt wird.
Dazu habe ich das HC-12 Modul an Pin 0 und 1 (Rx, Tx) gehängt und den Code entsprechend ergänzt. Doch jetzt hängt der Code beim Initialisieren des MP3-Moduls (DFPlayer Mini)
Weiss jemand weshalb der Code jetzt bockt?
Nachfolgend der Code bis zum main loop:
#include "DFRobotDFPlayerMini.h"
#include "SoftwareSerial.h"
SoftwareSerial mySoftwareSerial(8, 11);
SoftwareSerial HC12(0, 1);
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
// Digital IO's
int triggerPin             = 3;      // Push button for primary fire. Low = pressed
int trigger2Pin            = 13;     // Push button for secondary fire. Low = pressed
int speakerPin             = 4;      // Direct output to piezo sounder/speaker
int HitVibration           = 9;      // Audio Trigger. Can be used to set off sounds recorded in the kind of electronics you can get in greetings card that play a custom message.
int lifePin                = 6;      // An analogue output (PWM) level corresponds to remaining life. Use PWM pin: 3,5,6,9,10 or 11. Can be used to drive LED bar graphs. eg LM3914N
int ammoPin                = 5;      // An analogue output (PWM) level corresponds to remaining ammunition. Use PWM pin: 3,5,6,9,10 or 11.
int hitPin                 = 7;      // LED output pin used to indicate when the player has been hit.
int IRtransmitPin          = 2;      // Primary fire mode IR transmitter pin: Use pins 2,4,7,8,12 or 13. DO NOT USE PWM pins!! More info: http://j44industries.blogspot.com/2009/09/arduino-frequency-generation.html#more
//int IRtransmit2Pin         = 8;      // Secondary fire mode IR transmitter pin:  Use pins 2,4,7,8,12 or 13. DO NOT USE PWM pins!!
int IRreceivePin           = 12;     // The pin that incoming IR signals are read from
int IRreceive2Pin          = 10;     // Allows for checking external sensors are attached as well as distinguishing between sensor locations (eg spotting head shots)
//Minimum gun requirements: trigger, receiver, IR led, hit LED.
// Player and Game details
int myTeamID               = 1;      // 1-7 (0 = system message)
int myPlayerID             = 1;     // Player ID
int myGameID               = 1;      // Interprited by configureGane subroutine; allows for quick change of game types.
int myWeaponID             = 0;      // Deffined by gameType and configureGame subroutine.
int myWeaponHP             = 0;      // Deffined by gameType and configureGame subroutine.
int maxAmmo                = 0;      // Deffined by gameType and configureGame subroutine.
int maxLife                = 0;      // Deffined by gameType and configureGame subroutine.
int automatic              = 0;      // Deffined by gameType and configureGame subroutine. Automatic fire 0 = Semi Auto, 1 = Fully Auto.
int automatic2             = 0;      // Deffined by gameType and configureGame subroutine. Secondary fire auto?
//Incoming signal Details
int received[18];                    // Received data: received[0] = which sensor, received[1] - [17] byte1 byte2 parity (Miles Tag structure)
int check                  = 0;      // Variable used in parity checking
// Stats
int ammo                   = 0;      // Current ammunition
int life                   = 0;      // Current life
// Code Variables
int timeOut                = 0;      // Deffined in frequencyCalculations (IRpulse + 50)
int FIRE                   = 0;      // 0 = don't fire, 1 = Primary Fire, 2 = Secondary Fire
int TR                     = 0;      // Trigger Reading
int LTR                    = 0;      // Last Trigger Reading
int T2R                    = 0;      // Trigger 2 Reading (For secondary fire)
int LT2R                   = 0;      // Last Trigger 2 Reading (For secondary fire)
// Signal Properties
int IRpulse                = 600;    // Basic pulse duration of 600uS MilesTag standard 4*IRpulse for header bit, 2*IRpulse for 1, 1*IRpulse for 0.
int IRfrequency            = 36;     // Frequency in kHz Standard values are: 38kHz, 40kHz. Choose dependant on your receiver characteristics
int IRt                    = 0;      // LED on time to give correct transmission frequency, calculated in setup.
int IRpulses               = 0;      // Number of oscillations needed to make a full IRpulse, calculated in setup.
int header                 = 4;      // Header lenght in pulses. 4 = Miles tag standard
int maxSPS                 = 10;     // Maximum Shots Per Seconds. Not yet used.
int TBS                    = 0;      // Time between shots. Not yet used.
// Transmission data
int byte1[8];                        // String for storing byte1 of the data which gets transmitted when the player fires.
int byte2[8];                        // String for storing byte1 of the data which gets transmitted when the player fires.
int myParity               = 0;      // String for storing parity of the data which gets transmitted when the player fires.
// Received data
int memory                 = 10;     // Number of signals to be recorded: Allows for the game data to be reviewed after the game, no provision for transmitting / accessing it yet though.
int hitNo                  = 0;      // Hit number
// Byte1
int player[10];                      // Array must be as large as memory
int team[10];                        // Array must be as large as memory
// Byte2
int weapon[10];                      // Array must be as large as memory
int hp[10];                          // Array must be as large as memory
int parity[10];                      // Array must be as large as memory
int HitPlayer               = 0;
  // Serial coms set up to help with debugging.
  mySoftwareSerial.begin(9600);
  HC12.begin(9600);
  Serial.println("Startup...");
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true){
      delay(0); // Code to compatible with ESP8266 watch dog.
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(25);  //Set volume value. From 0 to 30
  // Pin declarations
  pinMode(triggerPin, INPUT);
  pinMode(trigger2Pin, INPUT);
  pinMode(speakerPin, OUTPUT);
  //pinMode(audioPin, OUTPUT);
  pinMode(lifePin, OUTPUT);
  pinMode(ammoPin, OUTPUT);
  pinMode(hitPin, OUTPUT);
  pinMode(IRtransmitPin, OUTPUT);
  //pinMode(IRtransmit2Pin, OUTPUT);
  pinMode(IRreceivePin, INPUT);
  pinMode(IRreceive2Pin, INPUT);
  pinMode(HitVibration, OUTPUT);
  frequencyCalculations();   // Calculates pulse lengths etc for desired frequency
  configureGame();           // Look up and configure game details
  tagCode();                 // Based on game details etc works out the data that will be transmitted when a shot is fired
  digitalWrite(triggerPin, HIGH);      // Not really needed if your circuit has the correct pull up resistors already but doesn't harm
  digitalWrite(trigger2Pin, HIGH);     // Not really needed if your circuit has the correct pull up resistors already but doesn't harm
  myDFPlayer.play(3);
  for (int i = 1;i < 254;i++) { // Loop plays start up noise
    analogWrite(ammoPin, i);
    playTone((3000-9*i), 2);
  // Next 4 lines initialise the display LEDs
  analogWrite(ammoPin, ((int) ammo));
  analogWrite(lifePin, ((int) life));
  lifeDisplay();
  ammoDisplay();
  Serial.println("Ready....");
[code]
An Pin 0 und 1 ist schon die serielle Hardware Schnittstelle. Wieso machst du da nochmal SoftwareSerial?
Nebenbei, solltest du die mehr Gedanken über die Datentypen machen. Von 0-255 reicht byte. Variablen die nicht negativ sein müssen sollten unsigned sein. Und alles was sich nicht ändert (wie Pins) const.
Und Strings sind auch keine int Arrays
Dachte schon, dass ich ein "Verbrechen" begangen habe indem ich an 0 und 1 SoftwareSerial gemacht habe. Ich habe eben leider alle anderen DigitalPins (2-13) bereits belegt.
laurin123:
Wieso sollte das ein Verbrechen sein ?
Es macht nur Probleme, die man sonst nicht hat.
Dann musst du deine Pins anders belegen.
Z.B. kannst du auch die analogen A0-A5 auch als digitale verwenden.
Hi
Wo der HC12-Kram abgehandelt wird, habe ich nur übersehen, oder ist der Kram noch gar nicht implementiert?
An den ganzen INT solltest Du wirklich arbeiten - es schadet nicht, wenn man halbwegs versteht, was man da zusammen kopiert.
Keine Angst - auch ich kopiere noch gerne Programm-Fetzen zusammen, allerdings nimmt die Anpassung meist einen nicht unerheblichen Batzen an Zeit in Anspruch - in der Zeit kann man den Kram auch fast neu zusammen denken.
MfG
Wenn's ein NANO werden darf - Der hat auch noch A6 und A7 als Analog-IN (reine Analog-IN).
Alternativ kann man mit PortExpandern (nahezu) beliebig viele DI/DO zugänglich machen.
Diese sind dann vom Arduino natürlich externe Pins - aber normale digitalWrite/digitalRead gehen damit problemlos.
Ich kann die Analog INs als digitale In- und Outputs verwenden indem ich sie normal mit digital.write oder read mit den Nummern 14-19 adressiere, oder?
laurin123:
Ja, das geht. Oder mit A0 - A5 als digital (input/output) definieren.
Ok danke Dieter!
laurin123:
Ok danke Dieter!
Alles klar, gerne.
Habe jetzt das HC-12-Modul an Pin 4 und 10. Das Uno bleibt aber immer noch an der selben Stelle hängen, also beim Initialisieren des MP3-Moduls. Also an dieser Stelle:
Im Anhang noch der ganze Code..
LaserTag_Ver1_moded_sound_with_timeout_vibration_HC12_2.ino (20.3 KB)
Da du 2 Module mit SoftwareSerial betreiben willst, musst du das im Sketch auch richtig definieren.
Ich sehe da nur eine Schnittstelle SoftwareSerial.
Und den Sketch immer im Forum direkt posten.
Oh, okay. Und wie mach ich das konkret? Sorry hab das noch nie gemacht..
Danke Dieter
laurin123:
Danke Dieter
Sorry, hatte das übersehen.
Du hast im 1. Sketch beide Schnittstellen initialisiert.
Den aktuellen Sketch noch posten.
Hier der aktuellste Code..
(kann ihn nicht hier reinstellen, da er weit über 9'000 Zeichen ist)
laurin123:
Der ist an mobilen Geräten meist nicht zu lesen. Ich kann ihn nicht lesen.
Dann lösche unnützen Kram raus oder teile ihn in 2 Teile
Teil 1:
SoftwareSerial HC12(4, 10);
// Digital IO's
int speakerPin             = 14;      //
int lifePin                = 6;      //
int ammoPin                = 5;      //
int hitPin                 = 7;      //
int IRreceive2Pin          = 15;     //
int myGameID               = 1;
int maxAmmo                = 0;      //
int maxLife                = 0;      //
int automatic              = 0;      //  = Semi Auto, 1 = Fully Auto.
// Stats
int ammo                   = 0;
int life                   = 0;
// Code Variables
int timeOut                = 0;
int FIRE                   = 0;
int TR                     = 0;
int T2R                    = 0;
int LT2R                   = 0;
int IRpulse                = 600;
int IRt                    = 0;
int IRpulses               = 0;
int header                 = 4;
int maxSPS                 = 10;
int TBS                    = 0;
int byte1[8];
int byte2[8];
int myParity               = 0;
// Received data
int memory                 = 10;
int hitNo                  = 0;
// Byte1
int player[10];
int team[10];
// Byte2
int weapon[10];
int hp[10];
int parity[10];
int HitPlayer               = 0;
  HC12.begin(9600);
    while(true){
      delay(0);
  // Pin declarations
  configureGame();
  tagCode();
  myDFPlayer.play(3);
  lifeDisplay();
  ammoDisplay();
// Main loop most of the code is in the sub routines
void loop(){
  receiveIR();
  if(FIRE != 0){
    shoot();
    ammoDisplay();
  triggers();
// SUB ROUTINES
void ammoDisplay() { // Updates Ammo LED output
  float ammoF;
  ammoF = (260/maxAmmo) * ammo;
  if(ammoF <= 0){ammoF = 0;}
  if(ammoF > 255){ammoF = 255;}
  analogWrite(ammoPin, ((int) ammoF));
void lifeDisplay() { // Updates Ammo LED output
  float lifeF;
  lifeF = (260/maxLife) * life;
  if(lifeF <= 0){lifeF = 0;}
  if(lifeF > 255){lifeF = 255;}
  analogWrite(lifePin, ((int) lifeF));
void receiveIR() {
  int error = 0;
  if(digitalRead(IRreceivePin) == LOW){    // If the receive pin is low a signal is being received.
    digitalWrite(hitPin,HIGH);
    if(digitalRead(IRreceive2Pin) == LOW){ // Is the incoming signal being received by the head sensors?
      received[0] = 1;
    else{
      received[0] = 0;
    while(digitalRead(IRreceivePin) == LOW){
    for(int i = 1; i <= 17; i++) {                        // Repeats several times to make sure the whole signal has been received
      received[i] = pulseIn(IRreceivePin, LOW, 15000);  // pulseIn command waits for a pulse and then records its duration in microseconds.
    Serial.print("sensor: ");                            // Prints if it was a head shot or not.
    Serial.print(received[0]);
    Serial.print("...");
    for(int i = 1; i <= 17; i++) {  // Looks at each one of the received pulses
      int receivedTemp[18];
      receivedTemp[i] = 2;
      if(received[i] > (IRpulse - 200) &&  received[i] < (IRpulse + 200)) {receivedTemp[i] = 0;}                      // Works out from the pulse length if it was a data 1 or 0 that was received writes result to receivedTemp string
      if(received[i] > (IRpulse + IRpulse - 200) &&  received[i] < (IRpulse + IRpulse + 200)) {receivedTemp[i] = 1;}  // Works out from the pulse length if it was a data 1 or 0 that was received
      received[i] = 3;                   // Wipes raw received data
      received[i] = receivedTemp[i];     // Inputs interpreted data
      Serial.print(" ");
      Serial.print(received[i]);         // Print interpreted data results
    Serial.println("");                  // New line to tidy up printed results
    // Parity Check. Was the data received a valid signal?
    check = 0;
    for(int i = 1; i <= 16; i++) {
      if(received[i] == 1){check = check + 1;}
      if(received[i] == 2){error = 1;}
    // Serial.println(check);
    check = check >> 0 & B1;
    if(check != received[17]){error = 1;}
    if(error == 0){Serial.println("Valid Signal");}
    else{Serial.println("ERROR");}
    if(error == 0){interpritReceived();}
    digitalWrite(hitPin,LOW);
void interpritReceived(){  // After a message has been received by the ReceiveIR subroutine this subroutine decidedes how it should react to the data
  if(hitNo == memory){hitNo = 0;} // hitNo sorts out where the data should be stored if statement means old data gets overwritten if too much is received
  team[hitNo] = 0;
  player[hitNo] = 0;
  weapon[hitNo] = 0;
  hp[hitNo] = 0;
  // Next few lines Effectivly converts the binary data into decimal
  // Im sure there must be a much more efficient way of doing this
  if(received[1] == 1){team[hitNo] = team[hitNo] + 4;}
  if(received[2] == 1){team[hitNo] = team[hitNo] + 2;}
  if(received[3] == 1){team[hitNo] = team[hitNo] + 1;}
  if(received[4] == 1){player[hitNo] = player[hitNo] + 16;}
  if(received[5] == 1){player[hitNo] = player[hitNo] + 8;}
  if(received[6] == 1){player[hitNo] = player[hitNo] + 4;}
  if(received[7] == 1){player[hitNo] = player[hitNo] + 2;}
  if(received[8] == 1){player[hitNo] = player[hitNo] + 1;}
  if(received[9] == 1){weapon[hitNo] = weapon[hitNo] + 4;}
  if(received[10] == 1){weapon[hitNo] = weapon[hitNo] + 2;}
  if(received[11] == 1){weapon[hitNo] = weapon[hitNo] + 1;}
  if(received[12] == 1){hp[hitNo] = hp[hitNo] + 16;}
  if(received[13] == 1){hp[hitNo] = hp[hitNo] + 8;}
  if(received[14] == 1){hp[hitNo] = hp[hitNo] + 4;}
  if(received[15] == 1){hp[hitNo] = hp[hitNo] + 2;}
  if(received[16] == 1){hp[hitNo] = hp[hitNo] + 1;}
  parity[hitNo] = received[17];
  Serial.print("Hit No: ");
  Serial.print(hitNo);
  Serial.print("  Player: ");
  Serial.print(player[hitNo]);
  Serial.print("  Team: ");
  Serial.print(team[hitNo]);
  Serial.print("  Weapon: ");
  Serial.print(weapon[hitNo]);
  Serial.print("  HP: ");
  Serial.print(hp[hitNo]);
  Serial.print("  Parity: ");
  Serial.println(parity[hitNo]);
  HC12.write(player[hitNo]);
Ok, der erste Teil ist da.
Wie hastdu den DFplayer angeschlossen ?
RX auf TX und TX auf RX ?
Der DFplayer ist mit Sicherheits richtig angeschlossen weil er vor den Änderungen für den HC-12 funktioniert hatte..
Hier noch der 2. Teil:
 //This is probably where more code should be added to expand the game capabilities at the moment the code just checks that the received data was not a system message and deducts a life if it wasn't.
  if (player[hitNo] != 0){hit();}
  hitNo++ ;
void shoot() {
  if(FIRE == 1){ // Has the trigger been pressed?
    Serial.println("FIRE 1");
    sendPulse(IRtransmitPin, 4); // Transmit Header pulse, send pulse subroutine deals with the details
    delayMicroseconds(IRpulse);
    for(int i = 0; i < 8; i++) { // Transmit Byte1
      if(byte1[i] == 1){
        sendPulse(IRtransmitPin, 1);
        //Serial.print("1 ");
      //else{Serial.print("0 ");}
    for(int i = 0; i < 8; i++) { // Transmit Byte2
      if(byte2[i] == 1){
       // Serial.print("1 ");
    if(myParity == 1){ // Parity
    Serial.println("");
    Serial.println("DONE 1");
    myDFPlayer.play(1);
  if(FIRE == 2){ // Where a secondary fire mode would be added
    Serial.println("FIRE 2");
    sendPulse(IRtransmitPin, 4); // Header
    Serial.println("DONE 2");
FIRE = 0;
ammo = ammo - 1;
void HitFeedback () {
  while (HC12.available()) {
    HitPlayer = (HC12.read());
    if (HitPlayer = myPlayerID) {
    myDFPlayer.play(4);
void sendPulse(int pin, int length){ // importing variables like this allows for secondary fire modes etc.
// This void genertates the carrier frequency for the information to be transmitted
  int i = 0;
  int o = 0;
  while( i < length ){
    i++;
    while( o < IRpulses ){
      o++;
      digitalWrite(pin, HIGH);
      delayMicroseconds(IRt);
      digitalWrite(pin, LOW);
void triggers() { // Checks to see if the triggers have been presses
  LTR = TR;       // Records previous state. Primary fire
  LT2R = T2R;     // Records previous state. Secondary fire
  TR = digitalRead(triggerPin);      // Looks up current trigger button state
  //T2R = digitalRead(trigger2Pin);    // Looks up current trigger button state
  // Code looks for changes in trigger state to give it a semi automatic shooting behaviour
  if(TR != LTR && TR == LOW){
    FIRE = 1;
  if(T2R != LT2R && T2R == LOW){
    FIRE = 2;
  if(TR == LOW && automatic == 1){
    FIRE = 1;
  if(T2R == LOW && automatic2 == 1){
    FIRE = 2;
  if(FIRE == 1 || FIRE == 2){
    if(ammo < 1){FIRE = 0; noAmmo();}
    if(life < 1){FIRE = 0; dead();}
    // Fire rate code to be added here
void configureGame() { // Where the game characteristics are stored, allows several game types to be recorded and you only have to change one variable (myGameID) to pick the game.
  if(myGameID == 0){
    myWeaponID = 1;
    maxAmmo = 30;
    ammo = 30;
    maxLife = 3;
    life = 3;
    myWeaponHP = 1;
  if(myGameID == 1){
    myWeaponID = 1;
    maxAmmo = 100;
    ammo = 100;
    maxLife = 10;
    life = 10;
    myWeaponHP = 1;
  if(myGameID == 2){
    myWeaponID = 1;
    maxAmmo = 1000;
    ammo = 100;
    maxLife = 100;
    life = 100;
    myWeaponHP = 1;
void frequencyCalculations() { // Works out all the timings needed to give the correct carrier frequency for the IR signal
  IRt = (int) (500/IRfrequency);
  IRpulses = (int) (IRpulse / (2*IRt));
  IRt = IRt - 4;
  // Why -4 I hear you cry. It allows for the time taken for commands to be executed.
  // More info: http://j44industries.blogspot.com/2009/09/arduino-frequency-generation.html#more
  Serial.print("Oscilation time period /2: ");
  Serial.println(IRt);
  Serial.print("Pulses: ");
  Serial.println(IRpulses);
  timeOut = IRpulse + 50; // Adding 50 to the expected pulse time gives a little margin for error on the pulse read time out value
void tagCode() { // Works out what the players tagger code (the code that is transmitted when they shoot) is
  byte1[0] = myTeamID >> 2 & B1;
  byte1[1] = myTeamID >> 1 & B1;
  byte1[2] = myTeamID >> 0 & B1;
  byte1[3] = myPlayerID >> 4 & B1;
  byte1[4] = myPlayerID >> 3 & B1;
  byte1[5] = myPlayerID >> 2 & B1;
  byte1[6] = myPlayerID >> 1 & B1;
  byte1[7] = myPlayerID >> 0 & B1;
  byte2[0] = myWeaponID >> 2 & B1;
  byte2[1] = myWeaponID >> 1 & B1;
  byte2[2] = myWeaponID >> 0 & B1;
  byte2[3] = myWeaponHP >> 4 & B1;
  byte2[4] = myWeaponHP >> 3 & B1;
  byte2[5] = myWeaponHP >> 2 & B1;
  byte2[6] = myWeaponHP >> 1 & B1;
  byte2[7] = myWeaponHP >> 0 & B1;
  myParity = 0;
  for (int i=0; i<8; i++) {
   if(byte1[i] == 1){myParity = myParity + 1;}
   if(byte2[i] == 1){myParity = myParity + 1;}
   myParity = myParity >> 0 & B1;
  // Next few lines print the full tagger code.
  Serial.print("Byte1: ");
  Serial.print(byte1[0]);
  Serial.print(byte1[1]);
  Serial.print(byte1[2]);
  Serial.print(byte1[3]);
  Serial.print(byte1[4]);
  Serial.print(byte1[5]);
  Serial.print(byte1[6]);
  Serial.print(byte1[7]);
  Serial.print("Byte2: ");
  Serial.print(byte2[0]);
  Serial.print(byte2[1]);
  Serial.print(byte2[2]);
  Serial.print(byte2[3]);
  Serial.print(byte2[4]);
  Serial.print(byte2[5]);
  Serial.print(byte2[6]);
  Serial.print(byte2[7]);
  Serial.print("Parity: ");
  Serial.print(myParity);
void playTone(int tone, int duration) { // A sub routine for playing tones like the standard arduino melody example
  for (long i = 0; i < duration * 1000L; i += tone * 2) {
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
void dead() { // void determines what the tagger does when it is out of lives
  // Makes a few noises and flashes some lights
    playTone((1000+9*i), 2);
  Serial.println("DEAD");
  for (int i=0; i<10; i++) {
   analogWrite(ammoPin, 255);
   delay (500);
   analogWrite(ammoPin, 0);
   delay (500);
void noAmmo() { // Make some noise and flash some lights when out of ammo
  playTone(500, 100);
  playTone(1000, 100);
void hit() { // Make some noise and flash some lights when you get shot
  digitalWrite(HitVibration, HIGH);
  life = life - hp[hitNo];
  Serial.print("Life: ");
  Serial.println(life);
  playTone(500, 500);
  if(life <= 0){dead();}
  myDFPlayer.play(2);
  digitalWrite(HitVibration, LOW);
  lifeDisplay();
Hallo alle
Ich denke, dass mein Problem darin liegt, dass die zwei SoftwareSerials einander stören. Das UNO kann ja anscheinend nur auf ein SoftwareSerial aufs mal "hören".
Denkt ihr, dass ich eine AltSoftSerial (Rx = 8, Tx = 9) zusammen mit einer "normalen" SoftwareSerial als serielle Kommunikation nehmen soll?
