Hello, I wanted to make a distance sensor with LEDs signaling how near to the sensor the object is and with the LCD to display the distance itself, but I ran into a problem, there's no distance showing up.
const int trigPin = 10;
const int echoPin = 9;
const int ledCount = 3;
int ledPins[]={3,5,6};
int brightness = 0;
float distance, duration;
#include <LiquidCrystal.h>
LiquidCrystal lcd(0, 1, 2, 4, 12, 13);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(A1, OUTPUT);
pinMode(A2, OUTPUT);
pinMode(A3, OUTPUT);
lcd.begin(16,2);
lcd.print("Attalums cm:");
for(int thisLed = 0; thisLed < ledCount; thisLed++)
pinMode(ledPins[thisLed], OUTPUT);
digitalWrite(trigPin, LOW); // Lai trigPin būtu "attiestatīts" no iepriekšējām darbībām
delayMicroseconds(2);
digitalWrite(trigPin, HIGH); // Aktivizē ultraskaņas vilni, kas "atsitas" pret objektu,
delayMicroseconds(10); //un tiek uztrevrts ar sensoru, kas savienots ar echoPin
duration = pulseIn(echoPin, HIGH); //pulseIn funkcija nolasa, cik ilgi echoPin ir HIGH (tikpat cik ilgs ir vilnis)
//funkcija mērīs laiku, nobrīža, ka echoPin ir HIGH līdz LOW
distance = (duration*034) / 2;//izmantosim formulu, lai aprēķinātu attālumu : s=t*v (dalīts ar 2, jo distance tiek veikta 2x)
//skaņas ātrums ir 343 m/s = 0,0343 cm/miksrosekundes (jo tā mēra pulseIn)
if(distance >= 222 && distance <=330)//atkarībā no attāluma:tas sadalīts 3 vienādās daļās
analogWrite(A1, 0); //deg zaļā, brīdinošā gaisma, rezistora lielums tika apskatīts internetā
analogWrite(A2, 0);
analogWrite(A3, 255);
analogWrite(A1, 0);
analogWrite(A2, 0);
analogWrite(A3, 0);
lcd.setCursor(0, 1);
lcd.print(distance); //izvada attālumu
for(int thisLed = 0; thisLed < ledCount; thisLed=thisLed+1)//sarkano spuldzīšu degšanas ātrums un fade funkcija
for (brightness = 0; brightness <= 255; brightness += 15)
analogWrite(ledPins[thisLed], brightness);
delay(45);
for(int thisLed = ledCount-1; thisLed >= 0; thisLed=thisLed-1)
for (brightness = 255; brightness >= 0; brightness -= 15)
delay(45);
else if(distance >=113 && distance <222)
analogWrite(A1, 204); //deg dzeltenā, brīdinošā gaisma
analogWrite(A2, 51);
analogWrite(A3, 204);
delay(300);
analogWrite(A1, 0);
analogWrite(A2, 0);
analogWrite(A3, 0);
delay(30);
delay(30);
delay(400);
else if(distance >=3 && distance <113)
analogWrite(A1, 255); //deg sarkanā, brīdinošā gaisma
analogWrite(A2, 0);
analogWrite(A3, 0);
delay(200);
analogWrite(A1, 0);
analogWrite(A2, 0);
analogWrite(A3, 0);
delay(10);
delay(10);
