Hi
I am working with a NodeMCU esp2866 board, I did all the necessary configuration to program through the Arduino IDE software, the programs are uploaded 100% correctly but when the NodeMCU is loaded it does nothing. What could be happening?
Thank.
What are you expecting it to do ?
What sketch are you loading and how would you know that it is working ?
Try this sketch
static byte x = 0;
Serial.println(x++);
Set the baud rate of the Serial monitor to 115200. Does anything print on the Serial monitor ?
I set the serial monitor to 115200 but it shows nothing
What messages do you get when you upload the sketch ?
It appears to me that the program is uploaded and below it says
Leaving...
Hard reset via RTS pin...
That sounds OK
Which board have you got selected in the IDE and which IDE version are you using ?
It has worked for me, I just disconnected and reconnected the board. Why is this happening?
you can not turn it off, just press the reset button
It doesn't work when I press the reset button.
after pressing the reset button, close and reopen the port monitor
Thanks, but it still doesn't work, I tried another board and it works correctly, is there a way to repair it?
