Problem of sending read shift register data via modbus tcp/ip
I am working Shift Register chips (8) reading with arduino and I want to send over with modbus tcp/ip to PLC. But I have a problem with data conversion.
I read shift register values with uint64_t data type. But I cant send with modbus tcp.
How can I send faster and correct?
the code i'm working on ;
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoRS485.h> // ArduinoModbus depends on the ArduinoRS485 library
#include <ArduinoModbus.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 11);
EthernetClient ethClient;
ModbusTCPClient modbusTCPClient(ethClient);
IPAddress server(192, 168, 1, 10); // update with the IP Address of your Modbus server
#define NUMBER_OF_SHIFT_CHIPS   8
#define DATA_WIDTH   NUMBER_OF_SHIFT_CHIPS * 8
#define PULSE_WIDTH_USEC   5
#define POLL_DELAY_MSEC   1
#define BYTES_VAL_T uint64_t
int ploadPin        = 8;  // Connects to Parallel load pin the 165
int clockEnablePin  = 9;  // Connects to Clock Enable pin the 165
int dataPin         = 11; // Connects to the Q7 pin the 165
int clockPin        = 12; // Connects to the Clock pin the 165
BYTES_VAL_T pinValues;
BYTES_VAL_T oldPinValues;
/* This function is essentially a "shift-in" routine reading the
 * serial Data from the shift register chips and representing
 * the state of those pins in an unsigned integer (or long).
BYTES_VAL_T read_shift_regs()
    uint64_t bitVal;
    BYTES_VAL_T bytesVal = 0;
    /* Trigger a parallel Load to latch the state of the data lines,
    digitalWrite(clockEnablePin, HIGH);
    digitalWrite(ploadPin, LOW);
    delayMicroseconds(PULSE_WIDTH_USEC);
    digitalWrite(ploadPin, HIGH);
    digitalWrite(clockEnablePin, LOW);
    /* Loop to read each bit value from the serial out line
     * of the SN74HC165N.
    for(int i = 0; i < DATA_WIDTH; i++)
        bitVal = digitalRead(dataPin);
        /* Set the corresponding bit in bytesVal.
        bytesVal |= (bitVal << ((DATA_WIDTH-1) - i));
        /* Pulse the Clock (rising edge shifts the next bit).
        digitalWrite(clockPin, HIGH);
        digitalWrite(clockPin, LOW);
    return(bytesVal);
/* Dump the list of zones along with their current status.
void display_pin_values()
    Serial.print("Pin States:\r\n");
        Serial.print("  Pin-");
        Serial.print(i);
        Serial.print(": ");
        if((pinValues >> i) & 1)
            Serial.print("HIGH");
            Serial.print("LOW");
        Serial.print("\r\n");
 i = pos / 8;
  if (i >= 8) return;
  bitWrite(bit_readings[i], pos % 8, pinValues);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
    /* Initialize our digital pins...
    pinMode(ploadPin, OUTPUT);
    pinMode(clockEnablePin, OUTPUT);
    pinMode(clockPin, OUTPUT);
    pinMode(dataPin, INPUT);
    /* Read in and display the pin states at startup.
    pinValues = read_shift_regs();
    display_pin_values();
    oldPinValues = pinValues;
    // wait for 1 second
    /* Read the state of all zones.
    /* If there was a chage in state, display which ones changed.
    if(pinValues != oldPinValues)
        Serial.print("*Pin value change detected*\r\n");
    delay(POLL_DELAY_MSEC);
      if (!modbusTCPClient.connected()) {
    // client not connected, start the Modbus TCP client
    Serial.println("Attempting to connect to Modbus TCP server");
    if (!modbusTCPClient.begin(server, 502)) {
      Serial.println("Modbus TCP Client failed to connect!");
      Serial.println("Modbus TCP Client connected");
    // client connected
    // write the value of 0x01, to the HR at address 0x00
    if (!modbusTCPClient.holdingRegisterWrite(0x00, ***)) {
      Serial.print("Failed to write  ");
      Serial.println(modbusTCPClient.lastError());
I'm sorry for my bad english.
Thank you for help.! :slight_smile:
If you find it difficult to write in english use google-translate.
Write down in detail what you want to say in your native language and let do google-translate the translation. google-translate "knows" a lot of languages even madarin, Urdu, Xhosa, Paschtu etc.
I'm not familiar with modbus tcp/ip. Did you analyse a modbus tcp-IP-demo-code?
I guess it expects data to be send as bytes. But this is just a quick guessing without knowing it.
best regards Stefan
Then read them differently.
