Problem of water pump with code is working
Hi everyone, I've got a problem on water pump. I am using a fingerprint sensor (AS608) to control a water pump. When the fingerprint match, the water pump start pumping liquid for 5 seconds and then stop. I have try the code and it works. However, once i have unplug the connection with the PC and connect again, the water pump keep pumping without stop. I have upload the code again and cannot stop. May I know what is the problem? Thank you!
#include <Adafruit_Fingerprint.h>
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
#define RELAY_PIN       10
#define ACCESS_DELAY    5000 // Keep lock unlocked for 3 seconds
  // set the data rate for the sensor serial port
  finger.begin(57600);
  delay(5);
  if (finger.verifyPassword())
    while (1) { delay(1); }
  pinMode(RELAY_PIN, OUTPUT);
  digitalWrite(RELAY_PIN, HIGH);   //Switch off relay initially. Relay is LOW level triggered relay so we need to write HIGH.
  if ( getFingerPrint() != -1)
    delay(ACCESS_DELAY);
    digitalWrite(RELAY_PIN, LOW);
  delay(50);            //Add some delay before next scan.
// returns -1 if failed, otherwise returns ID #
int getFingerPrint()
  int p = finger.getImage();
  if (p != FINGERPRINT_OK)  return -1;
  p = finger.image2Tz();
  p = finger.fingerFastSearch();
  // found a match!
  return finger.fingerID;
Please remove all empty lines and please post schematics. Pictures of wiring is not useful.
Some more help: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
Did you try pushing the reset button in the uno?
You turn the relay on in setup()... and the fingerprint is failing to while(1)
I see, I just made a silly mistake, it works now, thanks!
But may I know why the water pump sometimes will operate once I connect to my PC, but sometimes not? Actually before I upload the code, the water pump did not operate even though it has 5v voltage to the pump :thinking:
Your pump is bad.
