Problem on a DigitalRead() Function.
Hello guys,
i was trying to read the digital values low and high on a arduino nano board and these value i was looked on a serial monitor but they always shows me 0(zero)low value.
i was already check my hardware that is ok i was check this state on a multimeter i was got the right values
on a multimeter but not get the values on board pin what was the issue is here i don't know .
below i was attached the sample code for the purpose of understanding Please look at once and tell me whenever and which position to be i was wrong?
Programm:
int ledPin = 13;   // LED connected to digital pin 13
int interPin = 5;  //pin d2 as input
int val = 0;       // variable to store the read value
int overrange = 20;
int over = 0;
  pinMode(ledPin, OUTPUT);      // sets the digital pin 13 as output
  pinMode(interPin, INPUT);        // sets the digital pin 5(d2)as input
  pinMode(overrange, INPUT);
  val = digitalRead(interPin);     // read the input pin
  delay(100);
  Serial.println(val);
  digitalWrite(ledPin, val);    // sets the LED to the button's value
Best Regards,
seggi.
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
If your button is wired between Vcc and pin, do you use a pull-down resistor?
If your button is wired between Gnd and pin, do you use a pull-up resistor?
What happens if you remove the button and wire the pin directly to Vcc or Gnd?
i was already check my hardware that is ok i was check this state on a multimeter i was got the right values on a multimeter but not get the values on board pin
So you either have made a mistake checking it, or somehow you have blown that pin. Have you tested it on another pin?
I think we need a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
Hello guys,
i want to read the digital values on the digital pin D2. But the problem is whenever i am trying to read values and these values ate printed onto the serial monitor they always shows me the 0(Low value).
my Hardware connection is also seems the right i was already check the state or value on to the multimeter they are showed me right values of high(5v) and low(0v) .
But whenever i am trying on to the arduino nano they cant be able to gave me the data.
What is the problem is here i don't know right now please suggest me something or help me to resolve this issue.
Belowe i am posting the actual code .
#include<stdio.h>
  delay(100);
  digitalWrite(ledPin, val);    // sets the LED to the input's value
Best Regards,
seggi.
Moderator edit:
tags added.
@seggi, please do not cross-post. Threads merged.
Then why is your code using the D5 pin?
This code clearly uses pin 5 not pin 2 as your comment says.
