Problem on transmitting random number using I2C
I'm trying to transmit random number and display to lcd using I2C
this is the master:
    if(strstr(message, "A"))
                  long randNumber;
                  randNumber = random(11111,99999);
                     Wire.beginTransmission(5);
                    Wire.write(randNumber);
                      Wire.endTransmission();
here's the slave which will display the generate random number.
 void receiveEvent(int howMany)
 char i;
  while(Wire.available() > 0)
    numbers[i] = Wire.read();
    i++;
lcd.print(numbers);
but it would only display unread characters or it gives error.
You don't give us much to go on. But the first issue I see is that you're sending values using write. You are then treating them as strings once you recieve them.
Just to get you a step closer, try changing your master to select values that fit within a byte (ie 0-255) and change your slave to look something like this
 char i;
    lcd.print(numbers[i],DEC);
    i++;
