problem on voice calling
I want to make a call to the number 9895040XXX, from 8589001XXX( which is inserted in the gsm module).
in coming call to 8589001XXX is available but out going call to 9895040XXX is not working
i have written the code like this:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.println(“Calling through GSM Modem”);
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
delay(2000);
mySerial.println(“ATD9895040519;”); //watch out here for semicolon at the end!!
Serial.println(“Called ATD9895040519”);
void loop() // run over and over
// print response over serial port
if (mySerial.available())
Serial.write(mySerial.read());
This is your third thread on this subject. This and your last are identical, and a previous one where you raise it after asking another question.
Is number four coming soon?
making voice call
make a call using GSM
You should have just continued with your first thread.
You should also always post code within code tags, not inline.
How to use this forum - please read
