Hi to everybody. I am using aN esp8266 Lolin NodeMCU v3 to collect data from some sensors printing data on the serial port. Then i developed a Processing application for reading from serial port and for writing data on a txt file. My processing application must run on a raspberry pi 3b+ connected to esp8266 through usb.
once i programmed my esp8266 from my pc(COM5), i can access serial data because the acquisition occurs correctly, but if i disconnect the usb and then i connect the usb again, the sensor does not work as the setup method does not start. if i press reset button on my esp8266 the sensor starts working.
i would like to avoid to press the reset button, because i need an automatic acquisition of data when opening the serial port, connecting esp8266 to raspberrypi through USB(dev/ttyUSB0).
can you help me, please? this is my code with libraries i'm using.
#include <Arduino.h>
#include "SparkFun_AS7265X.h"
#include <Adafruit_Sensor.h>
#include <Adafruit_MPU6050.h>
#include <Wire.h>
#include "RTClib.h"
const int TRIG_PIN = 14;
const int ECHO_PIN = 12;
const int TRIG_PIN2 = 13;
const int ECHO_PIN2 = 15;
float duration_us, distance_cm,duration_us2, distance_cm2;
const int numSens = 5;
AS7265X sensors[numSens];
Adafruit_MPU6050 mpu;
Wire.begin();
TCA9548A(5);
if (!mpu.begin()) {
Serial.println("Sensor init failed");
while (1)
yield();
setMPUParams(mpu);
for (int i = 0; i < numSens ; i++) {
TCA9548A(i);
//Serial.println();
if (sensors[i].begin() == false) {
Serial.println("Sensor does not appear to be connected. Please check wiring. Freezing...");
while (1)
setSensorParam(sensors[i], 50, AS7265X_GAIN_64X, AS7265X_MEASUREMENT_MODE_4CHAN_2);
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(TRIG_PIN2, OUTPUT);
pinMode(ECHO_PIN2, INPUT);
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
duration_us = pulseIn(ECHO_PIN, HIGH);
digitalWrite(TRIG_PIN2, LOW);
digitalWrite(TRIG_PIN2, HIGH);
duration_us2 = pulseIn(ECHO_PIN2, HIGH);
// calculate the distance
distance_cm = microsecondsToCentimeters(duration_us);
distance_cm2 = microsecondsToCentimeters(duration_us2);
String accData= "0";
String gyroData="0";
String degree = "0";
for (int i = 0; i < numSens; i++) {
TCA9548A(i);
sensors[i].takeMeasurements(); //This is a hard wait while all 18 channels are measured
DateTime test(2021,1,1,22,0,0);
printData(sensors[i], i, distance_cm,distance_cm2, lux, test.timestamp(DateTime::TIMESTAMP_FULL),accData, gyroData,degree);
