Problem passing array to a function
Hello, i’ve a programming problem passing an array to a function…
I’ve followed a post in this forum but i obtain an error:
In function ‘void normalProgram()’:
error: cannot convert ‘int ()[4]’ to 'int’ for argument ‘1’ to 'void uptime(int*)
I’ve done a lot of combinations…
Any idea?
void normalProgram(){
if(time >= display+1000){
        int uptimeinfo[4];
        lcd.clear();
        uptime(&uptimeinfo);
void uptime(int *returninfo){
uptime is expecting you to pass it an array element and you have passed it a standard int.
Sorry Mike but i have never programmed in C :frowning: so i can’t understand…
Trying to pass just an integer i’ve modified into
void loop(){
          uptime(uptimeinfo[0]);
but IDE tells me:
error: invalid conversion from ‘int’ to 'int*
What does it mean?
Nevertheless, i’d like to pass the array not just one element and i can’t understand the way :frowning:
In the C language, a variable that is declared as an array is the same as pointer.
So uptimeinfo is a pointer to the array uptimeinfo[4] and you can call the uptime function as follows:
uptime(uptimeinfo); // pass a pointer to the uptimeinfo array
There may be an easier way to do what you want, why not post the code in uptimeinfo with a brief description of the purpose of that function
