problem passing class pointer to function
Hi, I'm having a problem with passing class pointers to non class function as in the code fragment below
void setup() { // put your setup code here, to run once:
class TTest { public: void junk(TTest *x); };
void TTest::junk(TTest *x) { }
void Func(TTest *x) {
void loop() { // put your main code here, to run repeatedly:
It fails to compile stating that TTest is not declared in this scope on the line "void Func(TTest *x)" and I cant see why.
Is this a restriction in C++ not being able to passs a class pointer to a non class function ?
I would have thought this would be possible (its easy enough in object pascal).
It's caused by the mangling the IDE does for you. Create a TTest.cpp and a TTest.h tab and populate them with your class code as in any cpp program. Add #include "TTest.h" at the top of the ino & cpp tabs.
Thanks heaps wildbill.
That worked a treat. I guess I need to learn more about the mangling. I wouldn't have thought it would make a difference being in the same file, biut it obviously does.
Thanks again, Andrew
It's just that the IDE creates function prototypes for you. So it created a prototype for Func at the top of the ino file before the class was defined.
