When I pass a string to a function as a parameter, the whole string is received by the function however the sizeof function does not reveal its true length. This makes it difficult/impossible to work with the char array.
The sizeof function in the loop module correctly prints the string length as 9.
The sizeof function in the TestFunction module incorrectly prints the string length as 2!
char data2[] (which is functionally identical to char *data2 ) is a pointer to an array, which is a memory address, which is 2 bytes on the ATmega8 family.
If you want the length of the string, use the strlen() function (or some equivalent).
That's exactly correct. This is something that often trips up beginning C students. "data" is an array of characters, size 9, but "data2" is a pointer to (address of) that same array, in this case size 2. Replacing the line
Serial.println(sizeof(data2));
with
Serial.println(strlen(data2));
will almost deliver what you want. It prints "8" and not "9", because strlen counts all the characters up to but not including the 0 byte that terminates all C strings. The sizeof operator does include it. Try this:
I wouldn't really characterize this as an "issue" anymore at all. This is simply the way the C programming language works and completely expected behavior. Using sizeof() to determine the length of a string known only by its pointer is just plain incorrect. You must use strlen or its equivalent.
