Problem Programing Button to switch (Multifunction) Led Control
I am working on a project that uses a arduino to control a strip of programable leds, I have everything pretty well organized and set up but the menu in this project is kind of complicated for me as I just started working with arduinos. The colors and patterns all function but I am trying to keep it to one button to save on space and the main menu isn’t working. Any help would be greatly appreciated. I think the issue is with the main loop but I can’t seem to find it.
When I press the button it immediately drops a fade then a scanner. I’m sure it has to be something with the main loop or submenu switch.
Fade_Patterns.ino (349 Bytes)
Main_Menu.ino (2.69 KB)
Rainbow_Patterns.ino (298 Bytes)
Scanner_Patterns.ino (488 Bytes)
Series_Menu.ino (1.33 KB)
Solid_Colors_Kinda_Working_Colors_List1.ino (9.17 KB)
Solid_Colors.ino (13 KB)
Theater_Patterns.ino (304 Bytes)
You better read the stickies at top if you want response. Me (and most other) just press back when we see a huge pile of attached files.
so where is the code for the main menu? and why do you think it’s not working?
