I'm trying to program Blink's example code in my new ATtiny85 with my Arduino UNO SMD as ISP. I've followed this tutorial: http://hlt.media.mit.edu/?p=1229, but I had some errors. I've used Arduino's IDE v1.0.
Highlighted message:
'OUTPUT was not declared in this scope'
Error message:
Blink.cpp:8:21: error: Arduino.h: No such file or directory
Blink.cpp: In function 'void setup()':
Blink:10: error: 'OUTPUT' was not declared in this scope
Blink:10: error: 'pinMode' was not declared in this scope
Blink.cpp: In function 'void loop()':
Blink:14: error: 'HIGH' was not declared in this scope
Blink:14: error: 'digitalWrite' was not declared in this scope
Blink:15: error: 'delay' was not declared in this scope
Blink:16: error: 'LOW' was not declared in this scope
I think the problem isn't with wiring or Arduino, because if I select "Arduino UNO" board and verify the code it works perfectly! But if I change to "ATtiny85 w/ Arduino as ISP" I have the error above. I think something is wrong with ATtiny85 lib, or Arduino's IDE isn't including "Arduino.h" and other necessary files.
I tried this tutorial update. I've downloaded the alternative ATtiny's core and connected all the wires. I tried to burn bootloader and upload Blink's code, then I had a new error:
Problem uploading to board. See http://arduino.cc/en/Guide/Troubleshooting#upload for sugestions.
Error message:
Binary sketch size: 748 bytes (of a 8192 byte maximum)
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
avrdude: stk500_cmd(): protocol error
This is very likely because of a problem with the ArduinoISP sketch...
You can either lower the baud rate to 9600 or send me a Personal Message with your email address and I'll send you a version that works with Arduino 1.0.
I sent you a personal message. I'm waiting for the Arduino ISP.
Thank you very much! Now it works perfectly! I used the version of Arduino ISP (TinyISP) you sent me and it works. It still warning, but I'm just ignoring:
