problem rc receiver signal
exactly. All the other code required the servo to read exactly 14335.
Again, run the code yourself!
sorry guys i can't get my head round this.. i thought if i use val > 14335 it would work for any value greater than 14335 regardless of wether the value moves slightly.
pulseIn(rcpin, INPUT);
shouldn't this be
pulseIn(rcpin, LOW);
I think INPUT is defined as 0 anyway but just to clarify the code shouldn't it be LOW?
KeithRB:
I never saw any code of the OPs of the form ( (14335 ? val) ?? (val ? 14335)), other than your reply to OP which I thought was a typo and Arrch's misreading of it. Did OP edit his 14335/14535s in the original post?
Agreed
Guys thanks for all your help on this, it's late here in the UK so calling it a day. i'll run the code and try and get a better understanding. fantastic forum and thanks for helping me out.
Cheers
mustang493:
Hard to get your head around because you've gotten a lot of ideas, and some from every one of us has been wrong in one way or the other :slight_smile:
You could probably understand better if you broke it up like this?
  if (val > 15555){
     // joystick is FORWARD
  else if (val < 14444) {
     // joystick is REARWARD
  else {
     // joystick is NEUTRAL
I changed the numbers so we would quit misreading 14335/14535 :slight_smile:
Actually, this is a perfect illustration of why magic numbers are a bad idea.
#define LOW_VAL 14335
#define HIGH_VAL 14535
if(val < LOW_VAL)
else if(val > HIGH_VAL)
means you correct an error/erroneous value in one place, and the logic is far easier to see.
Arrch:
 if ( 14335 < val || val < 14535) {
Can be simplified to
if ( val != 14335) {
So you want the LED to be off at that value, and on otherwise? Seems a bit loft to expect it to be EXACTLY that value.
Actually I think that code simplifies to
if (val < 14535) {
Which is still in error, but not that error :slight_smile:
PaulS:
Absolutely!
