I would like to read the current of some devices so I have built a PCB with an ACS712 (20A) and arduino mini pro. I have connected as per indicated with their capacitors and I have added a resistor to get zero value when no load connected to the ACS712.
Unfortunately, when no load is connected to the ACS712, I am not getting zero value. I am getting a RAW value of 550 instead of 512, as it should be.
However, if I read the value at the analog input (A7), with a multimeter, on the arduino it is just 2.5v as it should.
What I do not understand is why the arduino is not giving me 512 when 2.5v on the analog A7……...
I have checked power on the arduino is right 5v, stable and I have tried 2 different arduinos with the same results.
I am pretty lost at the moment as no information found when googling.....
Any ideas?
Sketh is attached
