I have wired up 3 x DS18B20 sensors and are using Peter Andersons code (see below) to read the data. However, the output gives me correct temperatures for sensors 1 & 2 but 3 always reads zero.
I have swapped the sensors around, tried different resistors, connector wires, inputs, etc. all to no avail so it is clearly a problem with the code. I have checked it over but can't see anything obvious. Can you help please? The code is below.
// DS18B20_1 - Arduino
// Continually measures temperatures at three points using the Dallas DS18B20 on three
// separate Arduino pins.
// Uses the parasitic power mode
// Displays to a serial LCD operating at 9600 baud.
// Arduino Board DS18B20
// +5 VDC
// 4.7K
// 8 ---------------- |----- 2 (DQ) Note that terms 1 and 3 are grounded.
// 7 ---- same as above
// 6 ---- same as above
// Tx ---------------------------- To Serial LCD (LCD #117)
// copyright, Peter H Anderson, Baltimore, MD, May 5, '07
int n, dev_channel[34] = {9, 8, 7}, _1W_Pin;
for (n=0; n<1; n++)
_1W_Pin = dev_channel[n];
digitalWrite(_1W_Pin, LOW);
delay (100);
pinMode(_1W_Pin, INPUT); // sets the digital pin as input (logic 1)
delay(100);
Serial.print("### "); // set backlight intensity
int n, dev_channel[3] = {9, 8, 7}, _1W_Pin;
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
for (n=0; n<3; n++)
OneWireReset(_1W_Pin);
OneWireOutByte(_1W_Pin, 0xcc, 0);
OneWireOutByte(_1W_Pin, 0x44, 1); // perform temperature conversion, strong pullup for one sec
OneWireOutByte(_1W_Pin, 0xbe, 0);
LowByte = OneWireInByte(_1W_Pin);
HighByte = OneWireInByte(_1W_Pin);
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (n==0) // if its the first time, clear the LCD
Serial.print(" \n");
delay(100);
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print(" ");
delay(1000); // 5 second delay. Adjust as necessary
void OneWireReset(int _1W_Pin) // reset. Should improve to act as a presence pulse
pinMode(_1W_Pin, OUTPUT); // bring low for 500 us
delayMicroseconds(500);
void OneWireOutByte(int _1W_Pin, byte d, byte strong) // output byte d (least sig bit first).
byte n;
for(n=8; n!=0; n--)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds(5);
delayMicroseconds(60);
d=d>>1; // now the next bit is in the least sig bit position.
if(strong)
digitalWrite(_1W_Pin, HIGH); // One sec of strong +5 VDC
byte OneWireInByte(int _1W_Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead(_1W_Pin);
delayMicroseconds(50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return(d);
