Problem reading exactly 3 bytes from serial monitor
Hello,
I am trying to get Arduino to read 3 characters input from the serial monitor. The goal is to have the user type in a 3 character message, such as ABC, and have Arduino read these characters from the buffer and save them to variables called byte1, byte2, and byte3. I then want to execute different code based on what the message is. However, if I type ABC in the serial monitor, Serial.available() does not return 3. I am fairly new to Arduino, and perhaps I am not understanding the various variable types.
Here is my code:
byte byte1;
byte byte2;
byte byte3;
void setup(){
  //Initialize serial communication
  //Read Buffer
  if (Serial.available()== 3) {
    //Read buffer, store each byte to a variable
    byte1 = Serial.read();
    delay(100);
    byte2 = Serial.read();
    delay(100);
    byte3 = Serial.read();
Any suggestions?
Thanks :slight_smile:
Why wait waste 90-odd character periods between reading characters?
Serial monitor doesn't send anything until you hit "send", and then it may send more than you typed, depending on how "line-endings" is set.
If you want to read a character as it is sent, use a proper terminal emulator.
try
if (Serial.available() >= 2) {
