Problem reading MQQT message from Openhabian?
Have used this example below to trigger relays from my Openhabian server via MQQT. If I publish a message via MQQTLens (Google store MQQT-app) on the Car/Relay1 channel with the text "1" it works!
The problem is that Openhabians pre defined switch-item seems to only publish the text ON and OFF. I have tried to change the trigger/payload in below Sketch to ON and OFF instead of 1 and 0 to trigger the relay but no luck. Any ideas on how I can get Arduino to read ON and OFF?
The specific code I have played around with
 if (topicStr == "Car/Relay1")
    //turn the switch on if the payload is '1' and publish to the MQTT server a confirmation message
    if (payload[0] == '1') {
      digitalWrite(D8, HIGH);
    //turn the switch off if the payload is '0'
    else if (payload[0] == '0') {
      digitalWrite(D8, LOW);
//EJ: 4 Relay Switch over WIFI using MQTT and Home Assistant with OTA Support
//EJ: The only way I know how to contribute to the HASS Community... you guys ROCK!!!!!
//EJ: Erick Joaquin :-) Australia
// Original sketch courtesy of ItKindaWorks
//ItKindaWorks - Creative Commons 2016
//github.com/ItKindaWorks
//Requires PubSubClient found here: https://github.com/knolleary/pubsubclient
//ESP8266 Simple MQTT switch controller
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <ArduinoOTA.h>
void callback(char* topic, byte* payload, unsigned int length);
//EDIT THESE LINES TO MATCH YOUR SETUP
#define MQTT_SERVER "******"  //your MQTT IP Address
#define mqtt_user "******"
#define mqtt_password "******"
#define mqtt_port "1883"
const char* ssid = "******";
const char* password = "******";
//EJ: Data PIN Assignment on WEMOS D1 R2 https://www.wemos.cc/product/d1.html
// if you are using Arduino UNO, you will need to change the "D1 ~ D4" with the corresponding UNO DATA pin number
const int switchPin1 = D1;
const int switchPin2 = D2;
const int switchPin3 = D3;
const int switchPin4 = D4;
//EJ: These are the MQTT Topic that will be used to manage the state of Relays 1 ~ 4
//EJ: Refer to my YAML component entry
//EJ: feel free to replicate the line if you have more relay switch to control, but dont forget to increment the number suffix so as increase switch logics in loop()
char const* switchTopic1 = "Car/Relay1";
char const* switchTopic2 = "Car/Relay2";
char const* switchTopic3 = "Car/Relay3";
char const* switchTopic4 = "Car/Relay4";
WiFiClient wifiClient;
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
  //initialize the switch as an output and set to LOW (off)
  pinMode(switchPin1, OUTPUT); // Relay Switch 1
  digitalWrite(switchPin1, LOW);
  pinMode(switchPin2, OUTPUT); // Relay Switch 2
  digitalWrite(switchPin2, LOW);
  pinMode(switchPin3, OUTPUT); // Relay Switch 3
  digitalWrite(switchPin3, LOW);
  pinMode(switchPin4, OUTPUT); // Relay Switch 4
  digitalWrite(switchPin4, LOW);
  ArduinoOTA.setHostname("My Arduino WEMO"); // A name given to your ESP8266 module when discovering it as a port in ARDUINO IDE
  ArduinoOTA.begin(); // OTA initialization
  //TestLEDS
  pinMode(D8, OUTPUT);
  pinMode(D7, OUTPUT);
  digitalWrite(D7, HIGH);
  //start the serial line for debugging
  delay(100);
  //start wifi subsystem
  WiFi.begin(ssid, password);
  //attempt to connect to the WIFI network and then connect to the MQTT server
  reconnect();
  //wait a bit before starting the main loop
  delay(2000);
  //reconnect if connection is lost
  if (!client.connected() && WiFi.status() == 3) {
    reconnect();
  //maintain MQTT connection
  client.loop();
  //MUST delay to allow ESP8266 WIFI functions to run
  delay(10);
  ArduinoOTA.handle();
void callback(char* topic, byte* payload, unsigned int length) {
  //convert topic to string to make it easier to work with
  String topicStr = topic;
  //EJ: Note:  the "topic" value gets overwritten everytime it receives confirmation (callback) message from MQTT
  //Print out some debugging info
  Serial.println("Callback update.");
  Serial.print("Topic: ");
  Serial.println(topicStr);
void reconnect() {
  //attempt to connect to the wifi if connection is lost
  if (WiFi.status() != WL_CONNECTED) {
    //debug printing
    Serial.print("Connecting to ");
    Serial.println(ssid);
    //loop while we wait for connection
      Serial.print(".");
    //print out some more debug once connected
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
  //make sure we are connected to WIFI before attemping to reconnect to MQTT
  if (WiFi.status() == WL_CONNECTED) {
    // Loop until we're reconnected to the MQTT server
    while (!client.connected()) {
      Serial.print("Attempting MQTT connection...");
      // Generate client name based on MAC address and last 8 bits of microsecond counter
      String clientName;
      clientName += "esp8266-";
      uint8_t mac[6];
      WiFi.macAddress(mac);
      clientName += macToStr(mac);
      //if connected, subscribe to the topic(s) we want to be notified about
      //EJ: Delete "mqtt_username", and "mqtt_password" here if you are not using any
      if (client.connect((char*) clientName.c_str(), mqtt_user, mqtt_password)) { //EJ: Update accordingly with your MQTT account
        Serial.print("\tMQTT Connected");
        client.subscribe(switchTopic1);
        client.subscribe(switchTopic2);
        client.subscribe(switchTopic3);
        client.subscribe(switchTopic4);
        //EJ: Do not forget to replicate the above line if you will have more than the above number of relay switches
      //otherwise print failed for debugging
      else {
        Serial.println("\tFailed.");
        abort();
//generate unique name from MAC addr
String macToStr(const uint8_t* mac) {
  String result;
  for (int i = 0; i < 6; ++i) {
    result += String(mac[i], 16);
    if (i < 5) {
      result += ':';
  return result;
As On/Off start with the same character you could just check the second char of the topic though this is dirty programming because your not checking the topic length.
Try copying the topic into a String and comparing that way.
