Problem reading pwm value sent from GUI (VB.net)
I recently developed a wi-fi controlled 4 wheel car that uses a router and an ethernet shield instead of the x-bee module. I can control the forward, backward, left, and right controls from the GUI by sending characters like : ‘A’ for forward, ‘B’ for backward etc. What I also want to do now is send a numeric value (0~255) from my GUI through a scrollbar control into the arduino via the serial protocol. I am sending a numeric value from my GUI but I can’t get to set the pwm in my arduino according to that value. Why is this happening? Is my syntax wrong in the arduino sketch?
void setup(){
pinMode(up,OUTPUT);
pinMode(down,OUTPUT);
pinMode(left,OUTPUT);
pinMode(right,OUTPUT);
int pwm = 0;
void loop(){
int val;
if (Serial.available()){
while (Serial.available()>0){
val = Serial.read();
if (val>=0){ //i want to set pwm for motor driver according to the value (0~255) I sent from GUI
pwm = val;}
else if(val==‘0’){
pwm = 0;
if(val==‘A’){ // I am using a character ‘A’ so that pwm and navigation instructions are not messed up . THIS PART IS WORKING FINE EXCEPT FOR PWM.
analogWrite(up,pwm);analogWrite(down,0);} //motor driver input1 and input 2
else if(val==‘0’){
analogWrite(up,0);analogWrite(down,0); //grounding both inputs for braking
if (val==‘B’){
analogWrite(up,0);analogWrite(down,pwm);}
else if(val==‘0’){
How are you doing that?
Well, lovely. As a string? Or, as binary data?
but I can't get to set the pwm in my arduino according to that value.
Perhaps because you are sending a string and expecting binary data. Send what you expect, or expect what you send.
I am sending scrollbar values as binary in the range 0-255. No problem on that part of the GUI!
      pwm = val;}
        else if(val=='0'){
          pwm = 0;
Under what conditions will the else clause ever be evaluated?
You need to post your PC code.
