Hello,
i am new to Arduino and i have a problem reading some serial data with the arduino hardware.
The data is send from a pc using the com port at 9600 baud (9600 8N1). Example data:
CA 00 00 03 00 05 7E 04 C9 CB 00 CB 01 CC B2 8D
Interesting for me are the bytes after 7E so i started with the following:
int redPIN = 9;
byte incomingByte;
if(Serial.available() >0) {
incomingByte = Serial.read();
switch(incomingByte) {
case 0x7E:
startByte();
default:
int startByte() {
//blink();
byte value;
value = Serial.read();
if(value==0x04) {
blink();
int blink()
analogWrite(redPIN, 255);
delay(10);
analogWrite(redPIN, 0);
Now it seems that it recognizes the 7E and startByte() will be called but after that i can´t get the additional bytes read like the value (0x04) in the startByte() function. blink() won´t be called.
The blink() function is only for debugging so don´t wonder g
Any ideas where the problem is?
best regards
Wotan
