Problem reading serial port through HC-05
Hello I have these two codes Master and Slave
Master
const int sensorPin = A0;
  pinMode(sensorPin, INPUT);
  int sensorVal = analogRead(sensorPin);
  float voltage = (sensorVal/1024.0)* 5.0;
  float temperature = (voltage-0.5)*100;
  Serial.println(temperature);
  delay(2000);
Slave
char c;
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
const float baseline = 15.0;
float temp;
void setup(){
   pinMode(7, OUTPUT);
   pinMode(6, OUTPUT);
   pinMode(5, OUTPUT);
   digitalWrite(7, LOW);
   digitalWrite(6, LOW);
   digitalWrite(5, LOW);
  recvWithEndMarker();
  showNewData();
void recvWithEndMarker() {
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
  // if (Serial.available() > 0) {
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (rc != endMarker) {
     receivedChars[ndx] = rc;
     ndx++;
      if (ndx >= numChars) {
      ndx = numChars - 1;
    else {
      receivedChars[ndx] = '\0'; // terminate the string
      ndx = 0;
      newData = true;
void showNewData() {
 if (newData == true) {
   temp = atof(receivedChars);
   Serial.println(temp);
   newData = false;
  if (temp > baseline && temp < baseline+10){
    digitalWrite(7, HIGH);
  else if(temp >= baseline+11 && temp < baseline+20){
    digitalWrite(6, HIGH);
  else if(temp >= baseline+21 && temp < baseline +30){
    digitalWrite(5, HIGH);
I've tried this before without problem, I re-configured the HC-05 modules and they stablish the communication correctly but I still got nothing on Serial Monitor (i've attached a screenshot)
hugorogz:
Were you using the exact same code as you posted above?
have you tried it without the Serial Monitor open on the master's com port? I don't know if this causes problems. I've always only had a serial port opened by one device at a time but it may well be fine to do this.
I suggest adding some debugging serial prints to the slave sketch so you can get a better idea of what's happening
Have you a HC05 on both Arduinos (what types of Arduino?) and is the Master connected to the PC using the USB cable?
What Arduino pins are the two HC05s connected to?
...R
