Hello,
This message was also posted on the Networks sub-boards. Being a beginner with Arduino, I try my few sketches, and I am currently facing a problem when trying to read a dummy value sent through bluetooth. Here is the sketch adapted from a LED example:
#include <ArduinoBLE.h>
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // BLE LED Service
BLEByteCharacteristic fooCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite );
const int ledPin = LED_BUILTIN; // pin to use for the LED
while (!Serial);
// set LED pin to output mode
pinMode(ledPin, OUTPUT);
// begin initialization
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
// set advertised local name and service UUID:
BLE.setLocalName("LED");
BLE.setAdvertisedService(ledService);
// add the characteristic to the service
ledService.addCharacteristic(fooCharacteristic);
// add service
BLE.addService(ledService);
// start advertising
BLE.advertise();
Serial.println("BLE LED Peripheral");
// listen for BLE peripherals to connect:
BLEDevice central = BLE.central();
float testfloat = 3.14152;
// if a central is connected to peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's MAC address:
Serial.println(central.address());
// while the central is still connected to peripheral:
while (central.connected()) {
fooCharacteristic.writeValue((byte)testfloat);
// when the central disconnects, print it out:
Serial.print(F("Disconnected from central: "));
With this on the device, I can connect with gatttool on linux.
hms@joe:~/projects/arduino$ gatttool -I
[ ][LE]> connect fc:57:4a:cb:ea:2e
Attempting to connect to fc:57:4a:cb:ea:2e
Connection successful
[fc:57:4a:cb:ea:2e][LE]> char-read-uuid 19B10001-E8F2-537E-4F6C-D104768A1214
Error: Read characteristics by UUID failed: Attribute PDU was invalid
And so there is this error:
I can connect with LightBlue from Android, read a value, but it appears that the hex on binary value that is read does not correspond to the value that is written by the device.
What am I doing wrong here? Can it be a problem with my laptop (and me being dumb at reading the value on LightBlue)?
Thanks for yout help!
