Problem Receiving Values from ITG3200 Gyroscope using an Arduino UNO [solved]
Hello,
I am having an issue getting values from an ITG3200 gyroscope into the serial window, from an Arduino Uno. The gyroscope chip uses I2C communication protocol.
ITG3200 datasheet: https://www.sparkfun.com/datasheets/Sensors/Gyro/PS-ITG-3200-00-01.4.pdf
I have also been using the SparkFun hookup guide: ITG-3200 Hookup Guide - SparkFun Learn
The clk is not being used in my project and has been soldered together. I have connected the SDA and SCL and GND pins to the appropriate pins on the Arduino Uno. Initially, I began using the 5V pins on the Arduino UNO for the VDD and VLOGIC. The datasheet indicates 3.3V but for VDD and VLOGIC but the chip has an absolute maximum rating of 6V and I was using the UNO for limited amounts of time ( 10 second intervals).
I was able to get readings for a lot of my test runs, but then I would only get 3 or 4 readings everytime I started the program. I switched out the chip thinking I had damaged it, but got the same results. I have since tried 4 more chips and used the 3v3 voltage on the arduino but had the same issue. I tried different Arduino Unos but still had the same issue.
Here is my code:
  //The Wire library is used for I2C communication
#include <Wire.h>
//This is a list of registers in the ITG-3200. Registers are parameters that determine how the sensor will behave, or they can hold data that represent the
//sensors current status.
//To learn more about the registers on the ITG-3200,
char WHO_AM_I = 0 ;
char SMPLRT_DIV = 0x15;
char DLPF_FS = 0x16;
char GYRO_XOUT_H = 0x1D;
char GYRO_XOUT_L = 0x1E;
char GYRO_YOUT_H = 0x1F;
char GYRO_YOUT_L = 0x20;
char GYRO_ZOUT_H = 0x21;
char GYRO_ZOUT_L = 0x22;
//This is a list of settings that can be loaded into the registers.
//DLPF, Full Scale Register Bits
//FS_SEL must be set to 3 for proper operation
//Set DLPF_CFG to 3 for 1kHz Fint and 42 Hz Low Pass Filter
char DLPF_CFG_0 = 1 << 0;
char DLPF_CFG_1 = 1 << 1;
char DLPF_CFG_2 = 1 << 2;
char DLPF_FS_SEL_0 = 1 << 3;
char DLPF_FS_SEL_1 = 1 << 4;
//I2C devices each have an address. The address is defined in the datasheet for the device. The ITG-3200 breakout board can have different address depending on how
//the jumper on top of the board is configured. By default, the jumper is connected to the VDD pin. When the jumper is connected to the VDD pin the I2C address
//is 0x69.
char itgAddress = 0x69;
const int vlogicpin = 6;
const int vddpin = 7;
//In the setup section of the sketch the serial port will be configured, the i2c communication will be initialized, and the itg-3200 will be configured.
  //Create a serial connection using a 9600bps baud rate.
  pinMode(vddpin, OUTPUT);
  pinMode(vlogicpin, OUTPUT);
  digitalWrite(vddpin, HIGH);
  digitalWrite(vlogicpin, HIGH);
  //Initialize the I2C communication. This will set the Arduino up as the 'Master' device.
  Wire.begin();
  //Read the WHO_AM_I register and print the result
  char id = 0;
  id = itgRead(itgAddress, 0x00);
  Serial.print("ID: ");
  Serial.println(id, HEX);
  //Configure the gyroscope
  //Set the gyroscope scale for the outputs to +/-2000 degrees per second
  itgWrite(itgAddress, DLPF_FS, (DLPF_FS_SEL_0 | DLPF_FS_SEL_1 | DLPF_CFG_0));
  //Set the sample rate to 100 hz
  itgWrite(itgAddress, SMPLRT_DIV, 9);
//The loop section of the sketch will read the X,Y and Z output rates from the gyroscope and output them in the Serial Terminal
  //Create variables to hold the output rates.
  int xRate, yRate, zRate;
  //Read the x,y and z output rates from the gyroscope.
  xRate = readX();
  yRate = readY();
  zRate = readZ();
  //Print the output rates to the terminal, seperated by a TAB character.
  Serial.print(xRate / 14.375);
  Serial.print('\t');
  Serial.print(yRate / 14.375);
  Serial.print('\t');
  Serial.println((zRate / 14.375));
  //Wait 10ms before reading the values again. (Remember, the output rate was set to 100hz and 1reading per 10ms = 100hz.)
  delay(10);
//This function will write a value to a register on the itg-3200.
//Parameters:
// char address: The I2C address of the sensor. For the ITG-3200 breakout the address is 0x69.
// char registerAddress: The address of the register on the sensor that should be written to.
// char data: The value to be written to the specified register.
void itgWrite(char address, char registerAddress, char data)
  //Initiate a communication sequence with the desired i2c device
  Wire.beginTransmission(address);
  //Tell the I2C address which register we are writing to
  Wire.write(registerAddress);
  //Send the value to write to the specified register
  Wire.write(data);
  //End the communication sequence
  Wire.endTransmission();
//This function will read the data from a specified register on the ITG-3200 and return the value.
//Parameters:
// char registerAddress: The address of the register on the sensor that should be read
//Return:
// unsigned char: The value currently residing in the specified register
unsigned char itgRead(char address, char registerAddress)
  //This variable will hold the contents read from the i2c device.
  unsigned char data = 0;
  //Send the register address to be read.
    //Send the Register Address
  //End the communication sequence.
  //Ask the I2C device for data
  Wire.requestFrom(address, 1);
  //Wait for a response from the I2C device
  if (Wire.available()) {
    //Save the data sent from the I2C device
    data = Wire.read();
  //Return the data read during the operation
  return data;
//This function is used to read the X-Axis rate of the gyroscope. The function returns the ADC value from the Gyroscope
//NOTE: This value is NOT in degrees per second.
//Usage: int xRate = readX();
int readX(void)
  int data = 0;
  data = itgRead(itgAddress, GYRO_XOUT_H) << 8;
  data |= itgRead(itgAddress, GYRO_XOUT_L);
  return data;
//This function is used to read the Y-Axis rate of the gyroscope. The function returns the ADC value from the Gyroscope
//Usage: int yRate = readY();
int readY(void)
  int data = 0;
  data = itgRead(itgAddress, GYRO_YOUT_H) << 8;
  data |= itgRead(itgAddress, GYRO_YOUT_L);
  return data;
//This function is used to read the Z-Axis rate of the gyroscope. The function returns the ADC value from the Gyroscope
//Usage: int zRate = readZ();
int readZ(void)
  int data = 0;
  data = itgRead(itgAddress, GYRO_ZOUT_H) << 8;
  data |= itgRead(itgAddress, GYRO_ZOUT_L);
  return data;
I have researched this so much, I fear there may be a very easy solution I am overlooking. Please let me know if there is anymore information required.
Thanks,
Ross
The ITG3200 is old and outdated. The Arduino 5V boards (for example the Arduino Uno) is also getting outdated.
You could upgrade to a newer MPU-9250 and a Arduino Zero or Arduino MKR1000.
Do you still use pin 6 and 7 ? Or do you use the 3.3V pin to power the sensor ?
The code is not okay, see: Wire.requestFrom() should not have a beginTransmission or endTransmission. · Issue #1 · sparkfun/ITG-3200_Breakout · GitHub.
The ITG-3200 can read all 6 bytes of the gyro data at once. There is no need to read each byte seperately. The datasheet shows that a Repeated Start is used, but that is not in the code.
Can you show the output ? Is the sketch completely halted ? How long are the wires ?
Koepel thank you for your reply,
I was indeed the length of the wires. I need long wires for the project but when I shortened the length, the gyroscope gave me continuous values. I will look into the code that you mentioned and see if I can revise it to be better. This is the only hardware available to me at the moment. Thanks
