Problem regarding Motor Driver Dual H Bridge L298N with Ultrasonic Sensor HC-SR0
I would like to make a vehicle that will stop when the sensor detects that the distance is less than 10. However, I was unable to understand how to use the break command. Could any kind soul show me how to edit my code? Thank you very much!
//variable for motor
int INA = 2;
int INB = 4;
int INC = 7;
int IND = 6;
int ENA = 3;
int ENB = 5;
int SPEED = 120;
//variable for echo distance
int trigPin = 9;
int echoPin = 10;
long duration;
int distance;
//for motor
pinMode(INA,OUTPUT);
pinMode(INB,OUTPUT);
pinMode(INC,OUTPUT);
pinMode(IND,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(ENB,OUTPUT);
analogWrite(ENA,SPEED);
analogWrite(ENB,SPEED);
//for echo distance
pinMode(trigPin,OUTPUT);
pinMode(echoPin,INPUT);
distance=999;
int x=0;
while(x<1)
digitalWrite(INA,HIGH);
digitalWrite(INB,LOW);
digitalWrite(INC,LOW);
digitalWrite(IND,HIGH);
digitalWrite(INA,LOW);
digitalWrite(IND,LOW);
digitalWrite(trigPin,LOW);
delayMicroseconds(2);
digitalWrite(trigPin,HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin,HIGH);
distance = duration*0.017;
Serial.print("Distance: ");
Serial.println(distance);
if(distance < 10)
AFAIK, you don’t need to use break
just tell the motors to stop turning !
IF (distance < 10) THEN do motors_stop
To make the motor BRAKE, make both the direction pins LOW and keep the enable pin HIGH.
if(distance < 10)
brake;
void brake()
  digitalWrite(ENA,HIGH);
  delay(200);
