Hello,
I am quite a newbie at programming. I have possessed my arduino for a long time and have tinkered with it here and there, learning bits of code and how this all works.
Recently, I decided to undergo the ever-so-famous RFID door lock project. Guess what, I DID IT ;D. But there's a problem. The code I'm using seems to accept every single RFID tag I use. It's horrible!
I've spent about the past 24 hours (excluding sleep of course) trying to figure this out. I want it to accept the tags I put in the code and to deny the rest. I've looked all over these forums and the internet and it seems that others had similar problems, I just don't quite understand the codes and the fixes. Don't get me wrong, I'm not someone looking for a handout - I did my best to learn how this all works and I think I am getting the hang of it.
This is just so fustrating >:( since I have to get this done ASAP because I leave for the army soon. I'll post my code and a link to the website I started this project from.
//BEGIN CODE
#define servoPin 4 // control pin for servo motor (White or yellow wire of servo)
#define minPulse 500 // minimum servo position (Open position)
#define maxPulse 2200 // maximum servo position (Closed position)
#define rxPin 8 // SOUT pin of RFID module
#define txPin 9
#define enable 2 // /ENABLE pin of RFID module
#define LED1 13 // LED output pin
#define LED2 12 // other LED output pin for two-way LED (yellow)
#define switchPin 7
#include <SoftwareSerial.h>
boolean open = true; // default start up is to assume the lock is open
int val = 0;
char code[10];
int bytesread = 0;
int pulse, switchVal;
char tag1[10] = {'0', '4', '1', '5', 'E', 'D', '4', '8', 'C', 'B'}; // why won't you work!?!?!
char tag2[10] = {'3', '6', '0', '0', '8', 'E', '5', 'E', '6', '9'};
char tag3[10] = {'2', '1', '0', '0', 'D', 'F', 'A', 'A', 'F', '8'};
void LEDControl(int state){
switch (state){
case 1:
digitalWrite(LED1,HIGH);
digitalWrite(LED2,LOW);
case 2:
digitalWrite(LED2,HIGH);
digitalWrite(LED1,LOW);
case 3:
for(int y=0;y<5;y++){
delay(250);
delay(250);
boolean checkTag(char *tag){
for (int x=0;x<10;x++){
if( tag[x] != code[x]){
return false;
return true;
boolean findGoodTag(){
if (checkTag(tag1)){ return true;}
else if (checkTag(tag2)){ return true;}
else if (checkTag(tag3)){ return true;}
// Add more lines right here like the one above if you have more tags
else{
Serial.print("Bad tag: ");
Serial.println(code);
LEDControl(3);
return false;
void moveServo(){
if (open){
pulse = minPulse;
open = false;
LEDControl(1);
else if (!open){
pulse = maxPulse;
open = true;
LEDControl(2);
for (int x =1;x<150;x++){
delay (10); // don't know why this works, but it does
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(pulse); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
pinMode(servoPin, OUTPUT); // Set servo pin as an output pin
pinMode(LED1,OUTPUT); // Set LED pin as output
pinMode(LED2,OUTPUT); // Set LED pin as output
Serial.println("Begin");
pinMode(enable,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(enable, LOW); // Activate the RFID reader
pinMode(switchPin, INPUT);
SoftwareSerial RFID = SoftwareSerial(rxPin,txPin);
RFID.begin(2400);
switchVal = digitalRead(switchPin);
if((val = RFID.read()) == 10)
{ // check for header
if(switchVal == HIGH){
Serial.println("Button");
moveServo();
bytesread = 0;
while(bytesread<10)
{ // read 10 digit code
val = RFID.read();
if((val == 10)||(val == 13))
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if((bytesread == 10) && (findGoodTag()))
{ // if 10 digit read is complete
digitalWrite(enable, HIGH); // dectivate the RFID reader
moveServo();
