Problem RFID reader and button switch pbs-110 connected to esp8266 using arduino iot cloud
Hello all brother and sister. I was using arduino iot cloud and esp8266 connected with RFID reader and button switch. my code Under this problem. My destination is when I scan card for first time it will store in array and if I scan again it delete that item in array. make sur the process scanning is stop I push button switch and then array that store items when I scan it will show on dasboard message. but my problem is it do not show.
my code:
#include "thingProperties.h"
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN D4
#define RST_PIN D3
#define LED_red 01
#define LED_green 03
#define buzzerPin D8
#define buttonPin D0
MFRC522 mfrc522(SS_PIN, RST_PIN);
LiquidCrystal_I2C lcd(0x27, 16, 2);
struct Product {
    String id;
    String name;
    double price;
const int MAX_PRODUCTS = 10;
Product products[MAX_PRODUCTS];
int numProducts = 0;
String scannedProducts[MAX_PRODUCTS];
int numScannedProducts = 0;
String tagID = "";
double Total = 0.00;
bool pressed = false;
//int size = 5;
String items[MAX_PRODUCTS];
int numScanneditem;
void displayMessage(const String& line1, const String& line2, int delayTime);
  //delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
    addProduct("332EEE34", "Bottle", 1.00);
    addProduct("F37EB915", "Can", 2.00);
    addProduct("E3433814", "Basket", 3.00);
    pinMode(buttonPin, INPUT_PULLUP);
    lcd.init();
    lcd.backlight();
    lcd.clear();
    //lcd.setCursor(4, 0);
    lcd.print("Welcome!");
    lcd.setCursor(0, 1);
    lcd.print("Please scan me!!");
    SPI.begin();
    mfrc522.PCD_Init();
    delay(4);
    mfrc522.PCD_DumpVersionToSerial();
    pinMode(LED_red, OUTPUT);
    pinMode(LED_green, OUTPUT);
    pinMode(buzzerPin, OUTPUT);
  // items[0] = "hello";
  // items[1] = "my name";
  //delete[] items;
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
    ArduinoCloud.update();
    bool curentState = digitalRead(buttonPin);
    String scan;
      for(int i = 0; i < numScannedProducts; i++){
        scan += items[i] + ", ";
        if(items[i+1] == ""){
          scan+="Amount: " + String(Total) + "$";
    //delay(2000);
    scanning = scan;
    //clearArray();
     if (curentState == pressed) {
       //delay(2000);
       //clearArray();
       delay(2000);
    // for(int i = 0; i < MAX_PRODUCTS; i++){
    //     scan += items[i] + ", ";
    //     delay(1000);
    //     if(items[i+1] == ""){
    //       scan+="Amount: " + String(Total) + "$";
    //       break;
    //scanning = scan;
        resetScannedProducts();
        Total = 0;
        displayMessage("Thank You.", "Have a nice day!", 5000);
        displayMessage("Welcome!", "Please scan me!!",0);
        while(digitalRead(buttonPin) == pressed){
          if (getID()) {
          processRFID();
      else if (getID()) {
        processRFID();
void onIDChange()  {
  // Add your code here to act upon ID change
void onProductChange()  {
  // Add your code here to act upon Product change
void onPriceChange()  {
  // Add your code here to act upon Price change
void onScanningChange()  {
  // if(scanning == ""){
  //   displayMessage("Thank You.", "Have a nice day!", 5000);
  //   displayMessage("Welcome!", "Please scan me!!",0);
  // Add your code here to act upon Scanning change
//void onTotalChange()  {
  // Add your code here to act upon Total change
  // if (total == "") {
  //       resetScannedProducts();
  //       Total = 0;
  void onClickChange()  {
  // while(click == true){
  //   for(int i = 0; i < numProducts; i++){
  //         scanning = items[numProducts];
  //       scanning = "Amount: " + String(Total) + "$";
void clearStringArray() {
  for (int i = 0; i < sizeof(items) / sizeof(items[0]); i++) {
    items[i] = "";
void clearArray() {
    for (int i = 0; i < 100 ; i++) {
        items[i] = "";// Set each element to an empty string
        //delay(500);
void displayMessage(const String& line1, const String& line2, int delayTime = 1000) {
    lcd.clear();
    if(line1 == "Welcome!")
    else if(line1 == "Thank You.")
      lcd.setCursor(3, 0);
      lcd.setCursor(0,0);
    lcd.print(line1);
    lcd.print(line2);
    delay(delayTime);
boolean getID() {
    if (!mfrc522.PICC_IsNewCardPresent() || !mfrc522.PICC_ReadCardSerial()) {
        return false;
    tagID = "";
    for (uint8_t i = 0; i < 4; i++) {
        tagID.concat(String(mfrc522.uid.uidByte[i], HEX));
    tagID.toUpperCase();
    mfrc522.PICC_HaltA();
    return true;
void processRFID() {
    for (int i = 0; i < numProducts; i++) {
        if (tagID == products[i].id) {
            if (!isProductScanned(products[i].id)) {
                addProductAction(i, true);
                addProductAction(i, false);
void addProductAction(int index, bool adding) {
  //String item;
    digitalWrite(adding ? LED_green : LED_red, HIGH);
    tone(buzzerPin, adding ? 3250 : 2250);
    delay(250);
    digitalWrite(adding ? LED_green : LED_red, LOW);
    noTone(buzzerPin);
    displayMessage(adding ? "Adding:" : "Removing:",
                   adding ? products[index].name + " + " + String(products[index].price) + "$" : products[index].name + " - " +         String(products[index].price) + "$");
  //scanning = products[index].name +" "+ String(products[index].price) + "$";
    if (adding) {
        items[index] = products[index].name + " " + String(products[index].price) + "$";
        //scanning = products[index].name + " + " + String(products[index].price) + "$";
        Total += products[index].price;
        addScannedProduct(products[index].id);
        //size = removeItemFromArray(items, size, index);
        //scanning = "\x1b";
        Total -= products[index].price;
        removeScannedProduct(products[index].id);
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Item: " + String(numScannedProducts));
    //scanning = "Item: " + String(numScannedProducts) + " : " + products[index].name;
    lcd.print("Amount: " + String(Total) + "$");
    //delay(2000);
    //scanning = "Amount: " + String(Total) + "$";
void addProduct(const String& id, const String& name, double price) {
    if (numProducts < MAX_PRODUCTS) {
        products[numProducts] = {id, name, price};
        numProducts++;
boolean isProductScanned(const String& id) {
    for (int i = 0; i < numScannedProducts; i++) {
        if (scannedProducts[i] == id) {
            return true;
    return false;
void addScannedProduct(const String& id) {
    if (numScannedProducts < MAX_PRODUCTS) {
        scannedProducts[numScannedProducts] = id;
        numScannedProducts++;
void removeScannedProduct(const String& id) {
            for (int j = i; j < numScannedProducts - 1; j++) {
                scannedProducts[j] = scannedProducts[j + 1];
            numScannedProducts--;
void resetScannedProducts() {
  //scanning = scan;
please tell me the problem. Thank you.
