Problem running code
Hello,
First of all many thanks in advance for any help you can bring to me.
My main problem is:
I load the code to the board and everything works. When I unplug and plug the board, it just stops working, and it won't do anything until I load the code again.
What I'm using:
Arduino UNO + Arduino Ethernet + TP Link (to get wifi).
Two Dynamixel Servos controled through 74LS241.
Arduino pro mini to control a Zoom H4n recorder remotely.
Smartphone to send and receive OSC packages to the micro through wifi.
Code:
#include <SPI.h>
#include <Ethernet.h>
#include <DynamixelSerial.h>
#include <Z_OSC.h>
byte myMac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte myIp[]  = { 192, 168, 1, 30 };
int  serverPort  = 19000;
byte destIp[] =  { 192, 168, 1, 22 };
int  destPort = 18000;
Z_OSCServer server;
Z_OSCClient client;
Z_OSCMessage *rcvMes;
//OSC Packets to be sent//
char oscAdr[] = "/1/fader5/";
char oscAdr2[] = "/1/fader6/";
char oscAdr3[] = "/remote";
char oscAdr4[] = "/4/multitoggle/7/1";
char oscAdr5[] = "/4/multitoggle/6/1";
char oscAdr6[] = "/4/multitoggle/5/1";
float fCount=0;
float fCount2=0;
const int DATA = 2; // Pin to control the Servos through 74LS241
long int intValue=0;
char str[]="myslid";
int count =0;
int vel1=100;
int vel2=100;
int pos=0;
int pos2=0;
int gravant=0;
 Ethernet.begin(myMac ,myIp);
 server.sockOpen(serverPort);
 Dynamixel.begin(1000000,2);  // Iniciem el servo a 1Mbps al pin de control 2
//Setup Servos:
 Dynamixel.setMaxTorque(1,512); //Parell al 50%
 Dynamixel.setMaxTorque(2,512); //Parell al 50%
 Dynamixel.setSRL(1,2); // Retorna-ho tot del servo 1.
 Dynamixel.setSRL(2,2); // Del servo 2
 Dynamixel.setTempLimit(1,80); // Màxima temperatura de 80ºC
 Dynamixel.setVoltageLimit(1,65,160); // Alimentació entre 6,5 i 16V
 Dynamixel.setTempLimit(2,80); // Màxima temperatura de 80ºC
 Dynamixel.setVoltageLimit(2,65,160); // Alimentació entre 6,5 i 16V
//Pins to control Arduino pro mini.
 pinMode(8, OUTPUT);
 digitalWrite(8, HIGH);
 pinMode(9, OUTPUT);
 digitalWrite(9, HIGH);
  if(server.available())
  rcvMes=server.getMessage(); //If we get a packet, process it
  logMessage();
//Functions to send from UNO to Smartphone (works but not used yet):
void sendProcess()
  Z_OSCMessage message;
  message.setAddress(destIp,destPort);
  message.setZ_OSCMessage(oscAdr ,"ff" ,&fCount, &fCount2);
  client.send(&message);
void sendProcess2()
  Z_OSCMessage message2;
  message2.setAddress(destIp,destPort);
  message2.setZ_OSCMessage(oscAdr2 ,"f" ,&fCount);
  client.send(&message2);
//Process the packet recived from the smartphone:
void logMessage()
    uint16_t i;
    float floatValue;
    for(i=0 ; i<rcvMes->getArgsNum(); i++)
     switch( rcvMes->getTypeTag(i) )
         case 'i':
         intValue = rcvMes->getInteger32(i);
          if(( !strcmp(rcvMes->getZ_OSCAddress() ,"/audio1/rec"))&&(intValue==1)) //We want to record with Zoom H4n
           if(gravant==0)
           digitalWrite(8, LOW); // Sends the order to Arduino pro mini (which controls the recorder)
           delay(200);
           gravant=1;
          if(( !strcmp(rcvMes->getZ_OSCAddress() ,"/audio1/stop"))&&(intValue==1)) /*Same, but now we want to stop recording/*
           if(gravant==1)
           digitalWrite(9, LOW);
           delay(200);
           gravant=0;
           //Control position of servo 1
          if( !strcmp(rcvMes->getZ_OSCAddress() ,"/cam1/vertical"))
             pos = map(intValue, 0, 100, 575, 775);
             vel1=100;
             Dynamixel.moveSpeed(1,pos,vel1);
//Deceleration when we are reaching the desired position.
               while(Dynamixel.moving(1)==1)
                 if(abs(Dynamixel.readPosition(1)-pos)<300)
                   vel1=90;
                 if(abs(Dynamixel.readPosition(1)-pos)<250)
                   vel1=80;
                 if(abs(Dynamixel.readPosition(1)-pos)<200)
                   vel1=70;
                 if(abs(Dynamixel.readPosition(1)-pos)<150)
                   vel1=60;
                 if(abs(Dynamixel.readPosition(1)-pos)<100)
                   vel1=50;
                 if(abs(Dynamixel.readPosition(1)-pos)<50)
                   vel1=40;
                 if(vel1==40)
                 return;
          //Same with servo 2
          if( !strcmp(rcvMes->getZ_OSCAddress() ,"/cam1/horitzontal"))
            pos2 = map(intValue, 0, 100, 0, 1023);
            vel2=100;
            Dynamixel.moveSpeed(2,pos2,vel2);
              while(Dynamixel.moving(2)==1)
                 if(abs(Dynamixel.readPosition(2)-pos2)<300)
                   vel2=90;
                 if(abs(Dynamixel.readPosition(2)-pos2)<250)
                   vel2=80;
                 if(abs(Dynamixel.readPosition(2)-pos2)<200)
                   vel2=70;
                 if(abs(Dynamixel.readPosition(2)-pos2)<150)
                   vel2=60;
                 if(abs(Dynamixel.readPosition(2)-pos2)<100)
                   vel2=50;
                 if(abs(Dynamixel.readPosition(2)-pos2)<50)
                   vel2=40;
                 if(vel2==40)
                 return;
          //Other orders we can get from the smartphone...nothing to do yet.
          if( !strcmp(rcvMes->getZ_OSCAddress() ,"/cam1/zoom"))
          if( !strcmp(rcvMes->getZ_OSCAddress() ,"/cam1/focus"))
          if( !strcmp(rcvMes->getZ_OSCAddress() ,"/audio3/rec"))
           if( !strcmp(rcvMes->getZ_OSCAddress() ,"/audio1/pause"))
Any other information needed please let me know.
Thanks again!
Which Arduino is that code running on? Which one doesn't seem to be working properly?
The problem is with the Arduino UNO+Ethernet Shield.
Arduino pro mini is working fine.
Also I've tried different codes from other projects with the UNO and it just works as it should.
Thanks!
What hardware is connected to the Uno, how are you powering it?
Mark
I'm connecting the Arduino UNO to an Ethernet shield, then through pin 2 it's connected to the 74LS241, and with digital pins 8 and 9 it sends orders to the arduino pro mini.
The power is through USB.
Thanks!
I assume you mean (un)Plug the ethernet?
What happens if you push the reset button?
What happens if you unconnect the ppower and reconnect?
Oh no sorry if I wrote it wrong (I don't have a really good english). I meant that disconnecting the power and turning it on again is when the problem starts. Same happens if I push the reset button.
The Ethernet is not a problem, I can disconnect and when I connect it again works fine.
Sorry for the misunderstanding.
