problem running examples of tvout library(TVoutBeta1.zip)
i m trying to interface arduino leonardo with a tv.
i downloaded the tvout library 'TVoutBeta1.zip'.But the example included in the library doesn't compile.i tried every tvout libraries available in the internet.still i m not finding a solution. I experimented with the latest version of arduino IDE and even the older version. the problem still persists.the software shows the following error:
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Leonardo"
C:\Program Files\Arduino\libraries\TVout\TVout.cpp: In member function 'void TVout::tone(unsigned int, long unsigned int)':
C:\Program Files\Arduino\libraries\TVout\TVout.cpp:825: error: 'DDR_SND' was not declared in this scope
C:\Program Files\Arduino\libraries\TVout\TVout.cpp:825: error: 'SND_PIN' was not declared in this scope
C:\Program Files\Arduino\libraries\TVout\TVout.cpp: In member function 'void TVout::noTone()':
C:\Program Files\Arduino\libraries\TVout\TVout.cpp:876: error: 'PORT_SND' was not declared in this scope
C:\Program Files\Arduino\libraries\TVout\TVout.cpp:876: error: 'SND_PIN' was not declared in this scope
wud be grateful 4 any suggestions or solution
Check and see if the library is supposed to work with the Leonardo.
Tom.... :slight_smile:
How can you be "running" the examples, if you can't even get them to compile?
